    Graphic parts list for modern house
    6 Posts 5 Posters 564 Views 5 Watching
      schaferron1
      I have created a model of my modern small house using components. (floor truss, roof truss, plywood decking, steel connectors, 4 x 4 posts, 6'8" x 12' 0" sliding door units, etc.) I would like to create a graphic list of all of the components showing sizes, and quantities.
      I have generated a report using sketchup Pro 2014. Works well. In excel there may be a way to add components to a sum, but it seems overly cumbersome. I'm sure a program like pluspec might be able to achieve this but I would like to create this list using Sketchup 2014.
      Any suggestions?
      Thanks,
      Ron
      • U Offline
        unearthed
        Have a look in plugin store for Tig's components to grid - it places all a models components on a grid centered at the origin (0,0,0)
        http://sketchucation.com/pluginstore?pln=components_grid
        Growplan - People ∩ Plants ∩ Place
        windows 7 64b, 4GB RAM, SU 8.0.16846
        Gimp, QGIS, Vectorworks 12, Bricscad 11
          schaferron1
          components to a grid does work, but this really isn't exactly what I need. thanks though!
          Maybe a list version would work. Any suggestions for something that will list all components and give amounts of each component in model?
          Thanks,
          R
          • sdmitchS Offline
            sdmitch
            Ron
            A sample model and what you think the list should look like would be most helpful.
            http://sdmitch.blogspot.com/
              slbaumgartner
              Thanks,
              R
              It has a different goal, but maybe the CutList plugin would serve your needs?
                driven
                You can create your own reports by editing the example code found here http://www.sketchup.com/intl/en/developer/docs/tutorial_attrreporting
                I mentioned it before [anchor= goto=http://sketchucation.com/forums/viewtopic.php?f=79&t=50820#p460251:2d0zzw5x]here[/anchor:2d0zzw5x]
                john
