    Section Cut Lines Appearing Grey
    layout
    7 Posts 3 Posters 2.9k Views 3 Watching
    • S
      sexypox69
      I hope there isn't another thread equal to this....if there is let me apologize. I'm preparing some construction documents in layout 2014 with a tight schedule.
      My problem is, when i import my floor plans which i created from my sketchup model, the lines where the section plane cut appear grayed out when i use vector or hybrid. In raster they appear normal but raster doesn't give the quality of lines which I need. I have done this before and haven't come across this problem before....then again i used layout 2013 and version before.....this is my first time using 2014.
      Can anyone point me in the right direction.
      • S
        sexypox69
        Oh I forgot to add that everythng to the back appear normal in all modes
        • jujuJ
          juju
          Do you have access to SU Pro 2015? Try it there and see if problem persists?
          • S
            sexypox69
            No I don't but I came to realise the problem is with my sketchup model. I inserted another model in the same layout document and everything was perfect. So now I"m trying to figure out what about my model is causing this.
            • TIGT
              Perhaps some transparent face between the camera and what's beyond ?
              Or perhaps... are the section-plane entities still set to be visible ? [rather than just the section-cuts themselves] - these have a certain opacity too...
              • S
                sexypox69
                Well now I know for sure that it has to do with the section planes because I deleted all the section planes and put in new ones and everything works perfect in layout now. Just wish I knew exactly what was the problem with the section planes because it took me hours setting up all the new section cuts in the exact locations.
                • S
                  sexypox69
                  I think I figured it out. Originally I had the section planes withing a group and now that I have placed new section planes I did them outside the group.
