    UTC - SU 2015
    12 Posts 4 Posters 614 Views 4 Watching
    • micioneM Offline
      micione
      Hello.
      Does anyone know how for blocking the setting of UTC?
      • KrisidiousK Offline
        Krisidious
        Block it? or set it to be a certain time in all new models?
        By: Kristoff Rand
        • micioneM Offline
          micione
          Krisidious,
          yes,set it to be a certain time in all new models.
          • BoxB Offline
            Set the time you want then Save as Template.
            • micioneM Offline
              micione
              Yes, thank you,
              but every time I open a new project I always have to reset.
              This did not occur in previous versions.
              Is a bug or has been changed it on purpose?
              • BoxB Offline
                It works for me. Make sure you have the correct template opening.as default.
                  Krisidious
                  Yes, Template save should do it...
                  By: Kristoff Rand
                  • micioneM Offline
                    micione
                    All the templates start with shading set to UTC-07:00.
                    I think the Italian version has a bug.
                    I report to the SU team.
                    thanks
                      Krisidious
                      Something wrong there... I just confirmed that the UTC can be changed/set when making template in US version.
                      By: Kristoff Rand
                        Did you try changing the location manually under Model Info>Geo-Location? Do that in a fresh model and save as template making sure this new one is the default template.
                        • micioneM Offline
                          micione
                          Yes,I've tried everything.
                          But it does not work.
                          • micioneM Offline
                            micione
                            Exactly, Dave.
                            My time zone corresponds to "UTC + 01: 00".
                            Can I set it up, but it is not kept in memory. (As, instead, occurs in the previous versions)
