    Change number of facets in a circle.
    28 Posts 5 Posters 6.1k Views 5 Watching
      Back again, Crash Report #2349.
      Make a circle, change the number of facets and press 'enter' bugspat.
        driven
        what are your exact steps?
        I tried...
        1: made circle with circle tool
        2: typed 40s and hit Enter
        works every time
        changing via 'Entity Info' also works
        may be plugin related?
          I used the same procedure, so it might be plugin related, I would like to see these plugins certified as suitable for v 2015 but will use the sketchucation plugin manage to go through them one by one. It should not take long as I only have about five or six.
            File New
            ======== Starting GL ========
            CBaseGLView::OnInitialUpdate
            InitializeOpenGL
            GetActivePixelFormat
            Got PF= 40 from registry
            IsValidPixelFormatInfo
            requestedpf.accel=1
            ARB functions NOT available.
            nPfds=134
            Pixel format 6 does not do a swap copy.
            Pixel format 7 does not do a swap copy.
            Pixel format 8 does not do a swap copy.
            Pixel format 9 does not do a swap copy.
            Pixel format 10 does not do a swap copy.
            Pixel format 11 does not do a swap copy.
            Pixel format 18 does not do a swap copy.
            Pixel format 19 does not do a swap copy.
            Pixel format 20 does not do a swap copy.
            Pixel format 21 does not do a swap copy.
            Pixel format 22 does not do a swap copy.
            Pixel format 23 does not do a swap copy.
            Pixel format 30 does not do a swap copy.
            Pixel format 31 does not do a swap copy.
            Pixel format 32 does not do a swap copy.
            Pixel format 33 does not do a swap copy.
            Pixel format 34 does not do a swap copy.
            Pixel format 35 does not do a swap copy.
            Pixel format 42 does not do a swap copy.
            Pixel format 43 does not do a swap copy.
            Pixel format 44 does not do a swap copy.
            Pixel format 45 does not do a swap copy.
            Pixel format 46 does not do a swap copy.
            Pixel format 47 does not do a swap copy.
            Pixel format 54 does not do a swap copy.
            Pixel format 55 does not do a swap copy.
            Pixel format 56 does not do a swap copy.
            Pixel format 57 does not do a swap copy.
            Pixel format 58 does not do a swap copy.
            Pixel format 59 does not do a swap copy.
            Pixel format 66 does not do a swap copy.
            Pixel format 67 does not do a swap copy.
            Pixel format 68 does not do a swap copy.
            Pixel format 69 does not do a swap copy.
            Pixel format 74 does not do a swap copy.
            Pixel format 75 does not do a swap copy.
            Pixel format 76 does not do a swap copy.
            Pixel format 77 does not do a swap copy.
            Pixel format 82 does not do a swap copy.
            Pixel format 83 does not do a swap copy.
            Pixel format 84 does not do a swap copy.
            Pixel format 85 does not do a swap copy.
            Pixel format 90 does not do a swap copy.
            Pixel format 91 does not do a swap copy.
            Pixel format 92 does not do a swap copy.
            Pixel format 93 does not do a swap copy.
            Pixel format 40 is valid
            GLConfigUtils::GetActivePixelFormat ... returning specified format 40
            Make a context ... pf=40
            Got context @af6be80 error=0
            GL initialization succeeded
            UseHWAccelerationFirstTime
            Got vendor (NVIDIA Corporation) renderer(GeForce GTX 460/PCIe/SSE2)
            Returning 1
            Loaded ruby file: extensions.rb
            Loaded ruby file: langhandler.rb
            Loaded ruby file: sketchup.rb
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_dialog.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/!scfapitools.rbs
            Loaded ruby file: C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SketchUcation/SCF-myShortcuts.rb
            Loaded ruby file: C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SketchUcation/SCF-openPluginsFolder.rb
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf-rbztools.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_manager.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/sketchucation/scf_uninstaller.rbs
            Loaded ruby file: C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SketchUcation/sketchUcloud.rb
            Loaded ruby file: C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SketchUcation/SCF_loader.rb
            Loaded ruby file: !SketchUcation_loader.rb
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_advancedcameratools/advancedcameratools_main.rbs
            Loaded ruby file: C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su_advancedcameratools/actloader.rb
            Loaded ruby file: su_advancedcameratools.rb
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcfunctions_v1.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclassifier.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_overlays.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dctools.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcutils.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcconverter.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbs
            Loaded ruby file: C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su_dynamiccomponents/ruby/dcloader.rb
            Loaded ruby file: su_dynamiccomponents.rb
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/geometryhelpers.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/meshhelpers.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/triangulatorutility.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/fromcontours.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/fromscratch.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/smoovetool.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/stamptool.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/drapetool2.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/detailtool.rbs
            Loaded ruby file: c:/users/admin/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/su_sandbox/flipedgetool.rbs
            Loaded ruby file: C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su_sandbox/sandboxmenus.rb
            Loaded ruby file: su_sandbox.rb
            Loaded ruby file: C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/su_webtextures/webtextures_loader.rb
            Loaded ruby file: su_webtextures.rb
            Loaded ruby file: c:/programdata/sketchup/sketchup 2015/sketchup/plugins/imaginationvisualizer/iv_console.rbs
            Loaded ruby file: c:/programdata/sketchup/sketchup 2015/sketchup/plugins/imaginationvisualizer/iv_observers.rbs
            Loaded ruby file: c:/programdata/sketchup/sketchup 2015/sketchup/plugins/imaginationvisualizer/iv_paths.rbs
            Loaded ruby file: c:/programdata/sketchup/sketchup 2015/sketchup/plugins/imaginationvisualizer/iv_utils.rbs
            Loaded ruby file: c:/programdata/sketchup/sketchup 2015/sketchup/plugins/imaginationvisualizer/iv_textures.rbs
            Loaded ruby file: c:/programdata/sketchup/sketchup 2015/sketchup/plugins/imaginationvisualizer/localizations/iv_localization_en-us.rbs
            Loaded ruby file: c:/programdata/sketchup/sketchup 2015/sketchup/plugins/imaginationvisualizer/iv_localization.rbs
            Loaded ruby file: c:/programdata/sketchup/sketchup 2015/sketchup/plugins/imaginationvisualizer/iv_translator_geom.rbs
            Loaded ruby file: c:/programdata/sketchup/sketchup 2015/sketchup/plugins/imaginationvisualizer/iv_visualizer.rbs
            Loaded ruby file: c:/programdata/sketchup/sketchup 2015/sketchup/plugins/imaginationvisualizer/iv_initialize.rbs
            Loaded ruby file: c:/programdata/sketchup/sketchup 2015/sketchup/plugins/imaginationvisualizer/iv_menu_commands.rbs
            Loaded ruby file: c:/programdata/sketchup/sketchup 2015/sketchup/plugins/imaginationvisualizer/iv_menus.rbs
            Loaded ruby file: C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb
            Loaded ruby file: ImaginationVisualizer.rb
            Tool(SelectionTool)
            ***** First UI thread = 6996
            Start(Open)Commit(1)
            Start(Open)Commit(2)
            Start(Properties)Commit(3)
              driven
              have you updated Visualiser, they have a v2015 beta update...
              known issue with old version in v2015
                I have the latest version of visualizer, v1.2.
                  driven
                  does the splat still occur when you disable Visualizer in 'Extensions' [and restart SketchUp]?
                    The weird thing is that as I removed the extensions I still got the bugsplat. I have no further information except that with NO extensions it does not occur. Rather like painting a large object where you keep going around in circles. I cannot identify a single plugin but with no plugins it does not happen.
                    • TIGT Online
                      The SketchUcation Extension and the su_ standard ones are unlikely to cause a 'splat'.
                      The Visualizer has been fingered in some recent incompatibility issues...
                      If you disable just that Visualizer Extension and restart SketchUp is that effective in preventing the 'splat' ? [you can NOT just disable an Extension and expect things to change immediately - a restart is needed, because the tool is still loaded until you restart ]
                        Thanks, I understand a restart is required between disabling and testing and have done so in between each plugin removal. I have visualizer installed as well as the sketchucation tools and circles are behaving themselves when I change facet numbers. I will have to install one at a time with a check and go from there.
                          Hold the bus, when a circle is in a group or component, with visualizer there IS a bugsplat. One step further at least.
                            driven
                            file in a ticket at Visualizer Support and give them a link to this post...
                            they are very prompt at chasing things up...
                            john
                              No visualizer, same event when the circle is within a group within a component. Bleep.
                                The weird thing here is that in 2014, with a version of the model used in 2015, I can carry out that operation with no problems, it is driving me to distraction. I had a huge relief when 2015 turned up and for a while everything was great so this is almost certainly something within su 2015. Really bleeeeeeeep.
                                  driven
                                  does it also happen if you change the same in 'Entities Info'
                                  I tried it in a simple embedded group without issue for either method...
                                  can you post the simplest skp that fails [ saved just prior to the segment change...]
                                    I only know of one way to change the number of facets in a circle and that IS the entities info box. Getting the opinion that it is something to do with component and group management. When I open the program after a crash toolbars are lost completely from my custom setup and everything reverts to 'first opening' setup. The model is not something I feel comfortable posting as it is something I am hoping to sell at some stage.
                                      driven
                                      I was thinking more of grabbing any component adding a group inside, adding a circle into that...
                                      save it then type ' 36s >> Enter ' if it crashes post that skp...
                                        I reduced the model to the component I have been working on.
                                        Bleepin' thing
                                          driven
                                          well, the good news is it bugsplats for me as well...lol
                                          the model came in with errors, but su fixed those first...
                                          I been losing chunks and still get the bugsplat, so I submitted it...
                                          john
                                          • TIGT Online
                                            Now here's a thing...
                                            I don't have Visualizer etc...
                                            I tried your SKP.
                                            There were somethings that needed fixing under Model Info Statistics...
                                            But when I try to change the circle segmentation inside your nested entities I too get a BugSplat !
                                            Very weird. 😲
                                            You ought to submit a BugSplat report to SketchUp and have a copy of the file available...
                                            • 1 / 2
