    Change number of facets in a circle.
    28 Posts 5 Posters 6.1k Views 5 Watching
      driven
      does the splat still occur when you disable Visualizer in 'Extensions' [and restart SketchUp]?
        The weird thing is that as I removed the extensions I still got the bugsplat. I have no further information except that with NO extensions it does not occur. Rather like painting a large object where you keep going around in circles. I cannot identify a single plugin but with no plugins it does not happen.
          The SketchUcation Extension and the su_ standard ones are unlikely to cause a 'splat'.
          The Visualizer has been fingered in some recent incompatibility issues...
          If you disable just that Visualizer Extension and restart SketchUp is that effective in preventing the 'splat' ? [you can NOT just disable an Extension and expect things to change immediately - a restart is needed, because the tool is still loaded until you restart ]
            Thanks, I understand a restart is required between disabling and testing and have done so in between each plugin removal. I have visualizer installed as well as the sketchucation tools and circles are behaving themselves when I change facet numbers. I will have to install one at a time with a check and go from there.
              Hold the bus, when a circle is in a group or component, with visualizer there IS a bugsplat. One step further at least.
                driven
                file in a ticket at Visualizer Support and give them a link to this post...
                they are very prompt at chasing things up...
                  No visualizer, same event when the circle is within a group within a component. Bleep.
                    The weird thing here is that in 2014, with a version of the model used in 2015, I can carry out that operation with no problems, it is driving me to distraction. I had a huge relief when 2015 turned up and for a while everything was great so this is almost certainly something within su 2015. Really bleeeeeeeep.
                      driven
                      does it also happen if you change the same in 'Entities Info'
                      I tried it in a simple embedded group without issue for either method...
                      can you post the simplest skp that fails [ saved just prior to the segment change...]
                        I only know of one way to change the number of facets in a circle and that IS the entities info box. Getting the opinion that it is something to do with component and group management. When I open the program after a crash toolbars are lost completely from my custom setup and everything reverts to 'first opening' setup. The model is not something I feel comfortable posting as it is something I am hoping to sell at some stage.
                          driven
                          I was thinking more of grabbing any component adding a group inside, adding a circle into that...
                          save it then type ' 36s >> Enter ' if it crashes post that skp...
                            I reduced the model to the component I have been working on.
                            Bleepin' thing
                              driven
                              well, the good news is it bugsplats for me as well...lol
                              the model came in with errors, but su fixed those first...
                              I been losing chunks and still get the bugsplat, so I submitted it...
                                Now here's a thing...
                                I don't have Visualizer etc...
                                I tried your SKP.
                                There were somethings that needed fixing under Model Info Statistics...
                                But when I try to change the circle segmentation inside your nested entities I too get a BugSplat !
                                Very weird. ๐Ÿ˜ฒ
                                You ought to submit a BugSplat report to SketchUp and have a copy of the file available...
                                  driven
                                  I reduced it to a minimum size, copy pasted into a new drawing, and it persists...
                                  heres the new skp...prob_cir.skp
                                  • BoxB Offline
                                    You're working at a very small scale with lots of tiny segments and faces. Scaling up doesn't stop the bugsplats but I'd guess it's at the root of your problems.
                                    When opening it in 2014 faces will disappear rather than bugsplat.
                                    I would suggest if you want to work with so many segments in your curves that you work at a larger scale. Then resize the whole model when you are finished.
                                    Edit: Looks like you have found a bug. It is reproducible.
                                    http://i155.photobucket.com/albums/s296/storeben/SU/Bug.gif
                                      driven
                                      cross posted with you box, but you came to the same conclusion,
                                      ...I really think this is a new bug...
                                      EDITED out the embarrassing bit where I was certain it was the nesting...lol
                                      • BoxB Offline
                                        It's definitely a bug.
                                        It happens with polygons also and you don't even need the second circle.
                                        Draw a circle or poly of any size, draw a line in any direction from any endpoint on the shape, select the circle/poly and change the segments in entity info. Splat.
                                        I have submitted splats Referencing it as Circle Segment Bug.
                                          Glad it is not just me, this works fine even at that size in 2014.
                                          • genma saotomeG Offline
                                            genma saotome
                                            To splat or not to splat, that is the question...
                                            The answer seems to depend on the size of the circle. I can start SU, draw a small circle, select the outside edge and change the number of increments from 24 to 360 and it works.
                                            OTOH, start SU, draw circle of 702.1495m (yes, that is what I need to do), select the outside edge and change the number of increments from 24 to 360 and splat.
