    SketchUp 2015 is 64bit
    302 Posts 74 Posters 71.2k Views 74 Watching
    • KrisidiousK Offline
      Krisidious
      Good deal MRA. Might make a stand alone post for your issue and fix so that other Quadros will see it and will find it in searches.
      And even though you can't make a report, SU Team are on this forum and there's a good chance one of them will see things like this as we discuss it.
      By: Kristoff Rand
      • jeff hammondJ Offline
        jeff hammond
        @driven said:
        @krisidious said:
        They probably changed it because a Mac guy made it first... They do everything backwards. If you notice on SCF when you click on an image the X is on the left instead of the right. I just know it was a Mac user who made it that way. πŸ˜‰
        [attachment=1:262gdhoj]<!-- ia1 -->2014-11-10 12.00.24 am.png<!-- ia1 -->[/attachment:262gdhoj]
        i think kris is talking about the forum software (here).. the close X for an expanded image is at top-left.. (and sure. that's mac like)
        [attachment=0:262gdhoj]<!-- ia0 -->Screen Shot 2014-11-09 at 10.58.25 PM.png<!-- ia0 -->[/attachment:262gdhoj]
        re: the buttons.. on mac at least, they always (i think) have the 'positive' action on the right side then the cancel or other actions to the left.. (as shown in your @john screenshot.. that's consistent throughout the OS)
        dotdotdot
          Krisidious
          indeed I was... I wonder why the switched that button?
          By: Kristoff Rand
            rv1974
            First off this is amazing release at alst,- huge thank you Trimble team!
            From "What's New":
            Fixed an issue that could cause glued components to move when moving other model geometry.
            Hmm. I see no improvement- the glued geometry keeps on jumping πŸ˜’
            kk1.swf
            • emerald15E Offline
              emerald15
              Woo-Hoo! rotating rectangles all over the shop!
              • david_hD Offline
                david_h
                So one of my favorite little RB's was a plugin called "Repair Broken Lines" I had it programmed for right-click menu. It's pretty old, pretty simple but it was great for me.
                Can't seem to get it to work in 15. are there some equivalents or updates that anyone knows about?
                • david_hD Offline
                  david_h
                  Thanks Dan. I have that one. I guess I need to explore more its features.
                  D
                  • Dan RathbunD Offline
                    Dan Rathbun
                    ThomThom's CleanUp3 is supposed to have that functionalitry:
                    http://sketchucation.com/pluginstore?pln=tt_cleanup
                    EDIT (
                    I do not think the URL above is the one I posted!
                    Is someone perhaps secretly editing my posts ? If so stop now! At least come out in the open so a admin edit flag is shown.
                    So .. I am reposting it:
                    http://extensions.sketchup.com/en/content/cleanupΒ³
                    I'm not here much anymore.
                    • dane.teegardinD Offline
                      dane.teegardin
                      I just gotta say, this update is saving me countless hours in my week. I average about 125mb file size and loading, let alone navigating was horrendous. Before, I had SketchUp and working files installed on a RamDisk, still took a bit to load. Now its almost instant. I can't wait to get V-ray up and running. Working great on my Intel i7 3632QM, Intel HD4000, 16GB DDR3 Ram.
                      • FrederikF Offline
                        Frederik
                        @numerobis said:
                        So display performance without shadows is almost the same for me as in v8. Maybe in v2014 zooming is a bit faster (0.5fps πŸ˜‰ ) and v2014 is reaching the max fps a tad more quickly and more constant.
                        But how does it perform with SU 2015 64-bit...??? 😐
                        Cheers
                        Kim Frederik
                        • N Offline
                          numerobis
                          I have done some more testing now with a 20M poly file (10M faces)
                          http://abload.de/img/su2015_20m0uu2t.jpg
                          To load the file from SSD takes ~6sec.
                          I get ~7-9fps for rotating and 1-3fps for zooming without any switching to wireframe - for shaded view and xray.
                          ~663MB RAM used by SU.
                          In v8:
                          Loading 8-9sec
                          Rotating shaded 7-9fps but maybe a bit more lagging at the start.
                          Zooming ~1-3fps (1-4fps xray) - no wireframe.
                          ~714MB RAM used by SU.
                          (i7 3930K @4,7GHz, GTX 560 TI 2GB, Win7 x64)
                          So display performance without shadows is almost the same for me as in v8. Maybe in v2015 zooming is a bit faster (0.5fps πŸ˜‰ ) and v2015 is reaching the max fps a tad more quickly and more constant.
                          Some older tests in v8 incl. 3DSmax... http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=58225%26amp;p=529915
                          • N Offline
                            numerobis
                            sorry, typo... of course it is 2015 x64 not 2014 πŸ˜‰
                            ...corrected
                              archheni
                              High Poly count was never the only thing which caused SU to bog down in the past..maybe you should try to have more component instances (50k-60k) in let's say 10K-20K groups. More diverse geometry would certainly also help. I'm pretty sure you will see a difference πŸ˜„
                              • bazB Offline
                                baz
                                Perhaps we should retry the shadow speed test, I think that was what it was called, from a few years ago. Anybody still have it?
                                BTW I am getting random Windows explorer freezes when clicking on a Su file. And still no thumbs:(
                                • BoxB Offline
                                  I guess you mean this one. Them test model is still there.
                                  http://sketchucation.com/forums/viewtopic.php?f=72%26amp;t=20076%26amp;hilit=speed+test
                                  • jo-keJ Offline
                                    jo-ke
                                    I've got the same problem. I hope there will be a solution soon.
                                    http://sketchucation.com/forums/viewtopic.php?f=11%26amp;t=59774
                                    http://www.zz7.de
                                    • N Offline
                                      numerobis
                                      Yes, me too. Not only freezes but complete crashes of the windows explorer. Sometimes when i enter the folder and sometimes when i right click on a file (list view, Win 7 x64). I must be related to the preview. I can fix it disabling the preview window.
                                      If you look at the file summary you'll see that there are more than 120000 instances in this model.
                                      And i can say from a recent project that there is absolutely no difference. I noticed the model was becoming massively slower (in v8) after i added several thousand nested (hole cutting) instances (~67000) of one component. Total entity summary is now ~70000 instances of 55 component definitions and ~1500 groups). I tried this file in v2015 and i can say that it performs the same.
                                      • G Offline
                                        gt5
                                        @rich o brien said:
                                        Someone better start the 2016 wish list pronto πŸ˜‰
                                        My wish would be the same that I have every year: a true Mac version instead of something that just happens to run on a mac.
                                        • FrederikF Offline
                                          Frederik
                                          I've seen this in the past, but my knowledge about Mac is very limited, so please bare with me...
                                          What do you mean about a 'true Mac version'...?
                                          (I've never seen anybody asking for a 'true Win version')
                                          What's the difference between a true Mac version and the one you have now...?
                                          As far as I understand, it runs natively on the Mac OS, hence it's not just a clone...
                                          From various screen grabs, I've seen that it looks very Mac OS to me, so please explain what the difference is...
                                          Please also enlighten me about what advantages a "real" Mac version would have above the current Mac version...
                                          Cheers
                                          Kim Frederik
                                            jeff hammond
                                            hmm.. the mac version is a true mac app i thought.
                                            all the UI elements are native OS X panels/sheets/toolbars/buttons/dialogs/slidersetc.. (like, when you update your OS, sketchup's look changes accordingly).. it's not just a bad port.
                                            some of the elements are outdated and/or not used very often such as the panels used for things in the Window menu (entity info, soften/smooth, shadows, etc) and i really wish the UI would get an overhaul/modernized but still, the way it is now, i don't think it 'just happens to run on mac'
                                            a 'true' 2015 mac app would probably have the following: full screen mode, trackpad/ magic mouse support, versioning/ osx autosave, better retina support, and 64 bit..
                                            and probably integrate some of the newer UI elements and/or steal (borrow) design cues from apple applications such as Final Cut Pro X and iWork..
                                            anyway, i don't think sketchup is crippled at all on mac compared to windows and the suTeam seems to have accomplished giving all users of either platform an equal experience.. (well, some of the stuff is better on mac so nyah πŸ˜‰.. but then again, i think the material browser may be better on windows)
                                            dotdotdot
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 12 / 16
