    SketchUp Plugins for Architecture
    75 Posts 27 Posters 575.0k Views 27 Watching
    • KrisidiousK Offline
      Krisidious
      @skalp said:
      Little correction:
      The price for Skalp for Sketchup is 69$ or 59€.
      Real Section from GWD has become Skalp for SketchUp.
      Please remove Real Section from the list because it doesn't exists anymore.
      Keep up the good work!
      Done...
      By: Kristoff Rand
      • SkalpS Offline
        Skalp
        A plugin I use daily for my architectural work is: Stretch by Area
        It's a free plugin thats saves a lot of time!
        http://sketchucation.com/forums/viewtopic.php?p=483628%23p483628
        Skalp
        http://www.skalp4sketchup.com
          Krisidious
          Thanks... Added.
          By: Kristoff Rand
            Krisidious
            added survey tool...
            By: Kristoff Rand
              Krisidious
              Updated DoorMaker to Pro & Gold
              By: Kristoff Rand
              • jujuJ Offline
                juju
                Buildedge Plan ($29) no longer available, it's Buildedge Pro now ($75)
                  Krisidious
                  Done... Thanks.
                  By: Kristoff Rand
                  • jujuJ Offline
                    juju
                    I suppose profilebuilder 2 should be added to this list?
                      Krisidious
                      Indeed it should.
                      By: Kristoff Rand
                      • jujuJ Offline
                        juju
                        Visualizer $20.00 FREE
                        https://getvisualizer.com/
                        Shouldn't 1001bit also be mentioned under the roof section?
                          Krisidious
                          For the architecture plugins that cover other areas I just leave them. They each do too much to list. I'll make the change for Visualizer.
                          By: Kristoff Rand
                            Krisidious
                            By: Kristoff Rand
                              Seems some sections are not in alphabetic order ! πŸ˜‰
                              More easy for see if a program is on the list or not!
                              Render...
                              A special light analysis prog!
                              http://www.lightup-analytics.com/
                              • ElibjrE Offline
                                Elibjr
                                Wow! This is a great thread! Thank you so much. Under Render, remember to add Brighter 3D
                                http://www.brighter3d.com/ which are available for free and paid for $100.
                                • AureusA Offline
                                  Aureus
                                  OK, the list is already pretty big.
                                  Can I then drop this idea: we'll continue to build it but perhaps it's also time to hear some users' experiences. Comparing similar plugins, their work-efficiency, cost-efficiency, known issues...
                                    Krisidious
                                    Added Drafting tools Section.
                                    By: Kristoff Rand
                                      mk11
                                      Is anyone aware of a plugin that draws dashed lines in any direction? For purposed of drawing door/window swing direction on door surfaces. Tried TIG's 2D tools but appears I can't draw at an angle...
                                      Marc Kleinmann
                                      SU Pro 2015
                                      Mac & Win
                                      • pbacotP Offline
                                        Yes you can. Draw the edges first. The line style applies the styled line along an edge.
                                          Krisidious
                                          sketchup has a back edges which are hidden or dashed lines... If I recall there are a few hidden line dashed line plugins, but I never found it useful... I just wait and do line types in Layout.
                                          By: Kristoff Rand
                                          • jujuJ Offline
                                            juju
                                            LAND / SITE PLANNING:
                                            2DXY SiteSurvey tool, $25.
                                            http://extensions.sketchup.com/en/content/2dxy%E2%84%A2-sitesurvey%E2%84%A2-tools
                                            • 3 / 4
