    SketchUp Plugins for Architecture
    75 Posts 27 Posters 581.7k Views 27 Watching
    • GarethG Offline
      Gareth
      @massimo said:
      I think that this thread deserves to be sticky. πŸ‘
      Done.
      I think Kris deserves a beer....!!
      Great work Kris
      • KrisidiousK Offline
        Krisidious
        I don't think I've ever turned down a beer... 😎
        By: Kristoff Rand
          smuncky
          amazing list! thanks for this!
          • SkalpS Offline
            Skalp
            Little correction:
            The price for Skalp for Sketchup is 69$ or 59€.
            Real Section from GWD has become Skalp for SketchUp.
            Please remove Real Section from the list because it doesn't exists anymore.
            Keep up the good work!
            Skalp
            http://www.skalp4sketchup.com
              Krisidious
              @skalp said:
              Little correction:
              Done...
              By: Kristoff Rand
              • SkalpS Offline
                Skalp
                A plugin I use daily for my architectural work is: Stretch by Area
                It's a free plugin thats saves a lot of time!
                404 Not Found
                (sketchucation.com)
                Skalp
                  Krisidious
                  404 Not Found
                  (sketchucation.com)
                  Thanks... Added.
                  By: Kristoff Rand
                    Krisidious
                    added survey tool...
                    By: Kristoff Rand
                      Krisidious
                      Updated DoorMaker to Pro & Gold
                      By: Kristoff Rand
                      • jujuJ Offline
                        juju
                        Buildedge Plan ($29) no longer available, it's Buildedge Pro now ($75)
                          Krisidious
                          Done... Thanks.
                          By: Kristoff Rand
                          • jujuJ Offline
                            juju
                            I suppose profilebuilder 2 should be added to this list?
                              Krisidious
                              Indeed it should.
                              By: Kristoff Rand
                              • jujuJ Offline
                                juju
                                Visualizer $20.00 FREE
                                https://getvisualizer.com/
                                Shouldn't 1001bit also be mentioned under the roof section?
                                  Krisidious
                                  For the architecture plugins that cover other areas I just leave them. They each do too much to list. I'll make the change for Visualizer.
                                  By: Kristoff Rand
                                    Krisidious
                                    By: Kristoff Rand
                                      Seems some sections are not in alphabetic order ! πŸ˜‰
                                      More easy for see if a program is on the list or not!
                                      Render...
                                      A special light analysis prog!
                                      http://www.lightup-analytics.com/
                                      • ElibjrE Offline
                                        Elibjr
                                        Wow! This is a great thread! Thank you so much. Under Render, remember to add Brighter 3D
                                        http://www.brighter3d.com/ which are available for free and paid for $100.
                                        • AureusA Offline
                                          Aureus
                                          OK, the list is already pretty big.
                                          Can I then drop this idea: we'll continue to build it but perhaps it's also time to hear some users' experiences. Comparing similar plugins, their work-efficiency, cost-efficiency, known issues...
                                            Krisidious
                                            Added Drafting tools Section.
                                            By: Kristoff Rand
                                            • 3 / 4
