    SketchUp Plugins for Architecture
    75 Posts 27 Posters 584.2k Views 27 Watching
    • massimoM
      massimo Moderator
      I think that this thread deserves to be sticky. πŸ‘
      Done.
      • GarethG
        Gareth
        Done.
        I think Kris deserves a beer....!!
        Great work Kris
        • KrisidiousK
          Krisidious
          I don't think I've ever turned down a beer... 😎
          By: Kristoff Rand
            smuncky
            amazing list! thanks for this!
            • SkalpS
              Skalp
              Little correction:
              The price for Skalp for Sketchup is 69$ or 59€.
              Real Section from GWD has become Skalp for SketchUp.
              Please remove Real Section from the list because it doesn't exists anymore.
              Keep up the good work!
              Skalp
              http://www.skalp4sketchup.com
              • KrisidiousK
                Krisidious
                @skalp said:
                Little correction:
                Done...
                By: Kristoff Rand
                • SkalpS
                  Skalp
                  A plugin I use daily for my architectural work is: Stretch by Area
                  It's a free plugin thats saves a lot of time!
                  404 Not Found
                  (sketchucation.com)
                  Skalp
                  • KrisidiousK
                    Krisidious
                    404 Not Found
                    (sketchucation.com)
                    Thanks... Added.
                    By: Kristoff Rand
                    • KrisidiousK
                      Krisidious
                      added survey tool...
                      By: Kristoff Rand
                      • KrisidiousK
                        Krisidious
                        Updated DoorMaker to Pro & Gold
                        By: Kristoff Rand
                        • jujuJ
                          juju
                          Buildedge Plan ($29) no longer available, it's Buildedge Pro now ($75)
                          • KrisidiousK
                            Krisidious
                            Done... Thanks.
                            By: Kristoff Rand
                            • jujuJ
                              juju
                              I suppose profilebuilder 2 should be added to this list?
                              • KrisidiousK
                                Krisidious
                                Indeed it should.
                                By: Kristoff Rand
                                • jujuJ
                                  juju
                                  Visualizer $20.00 FREE
                                  https://getvisualizer.com/
                                  Shouldn't 1001bit also be mentioned under the roof section?
                                  • KrisidiousK
                                    Krisidious
                                    For the architecture plugins that cover other areas I just leave them. They each do too much to list. I'll make the change for Visualizer.
                                    By: Kristoff Rand
                                    • KrisidiousK
                                      Krisidious
                                      By: Kristoff Rand
                                        Seems some sections are not in alphabetic order ! πŸ˜‰
                                        More easy for see if a program is on the list or not!
                                        Render...
                                        A special light analysis prog!
                                        http://www.lightup-analytics.com/
                                        • ElibjrE
                                          Elibjr
                                          Wow! This is a great thread! Thank you so much. Under Render, remember to add Brighter 3D
                                          http://www.brighter3d.com/ which are available for free and paid for $100.
                                          • AureusA
                                            Aureus
                                            OK, the list is already pretty big.
                                            Can I then drop this idea: we'll continue to build it but perhaps it's also time to hear some users' experiences. Comparing similar plugins, their work-efficiency, cost-efficiency, known issues...
                                            • 3 / 4
