    SketchUp Plugins for Architecture
    75 Posts 27 Posters 582.9k Views 27 Watching
      smuncky
      amazing list! thanks for this!
      • SkalpS Offline
        Skalp
        Little correction:
        The price for Skalp for Sketchup is 69$ or 59€.
        Real Section from GWD has become Skalp for SketchUp.
        Please remove Real Section from the list because it doesn't exists anymore.
        Keep up the good work!
        Skalp
        http://www.skalp4sketchup.com
        • KrisidiousK Offline
          Krisidious
          @skalp said:
          Little correction:
          Done...
          By: Kristoff Rand
          • SkalpS Offline
            Skalp
            A plugin I use daily for my architectural work is: Stretch by Area
            It's a free plugin thats saves a lot of time!
            404 Not Found
            (sketchucation.com)
            Skalp
              Krisidious
              404 Not Found
              (sketchucation.com)
              Thanks... Added.
              By: Kristoff Rand
                Krisidious
                added survey tool...
                By: Kristoff Rand
                  Krisidious
                  Updated DoorMaker to Pro & Gold
                  By: Kristoff Rand
                  • jujuJ Offline
                    juju
                    Buildedge Plan ($29) no longer available, it's Buildedge Pro now ($75)
                      Krisidious
                      Done... Thanks.
                      By: Kristoff Rand
                      • jujuJ Offline
                        juju
                        I suppose profilebuilder 2 should be added to this list?
                          Krisidious
                          Indeed it should.
                          By: Kristoff Rand
                          • jujuJ Offline
                            juju
                            Visualizer $20.00 FREE
                            https://getvisualizer.com/
                            Shouldn't 1001bit also be mentioned under the roof section?
                              Krisidious
                              For the architecture plugins that cover other areas I just leave them. They each do too much to list. I'll make the change for Visualizer.
                              By: Kristoff Rand
                                Krisidious
                                By: Kristoff Rand
                                  Seems some sections are not in alphabetic order ! πŸ˜‰
                                  More easy for see if a program is on the list or not!
                                  Render...
                                  A special light analysis prog!
                                  http://www.lightup-analytics.com/
                                  • ElibjrE Offline
                                    Elibjr
                                    Wow! This is a great thread! Thank you so much. Under Render, remember to add Brighter 3D
                                    http://www.brighter3d.com/ which are available for free and paid for $100.
                                    • AureusA Offline
                                      Aureus
                                      OK, the list is already pretty big.
                                      Can I then drop this idea: we'll continue to build it but perhaps it's also time to hear some users' experiences. Comparing similar plugins, their work-efficiency, cost-efficiency, known issues...
                                        Krisidious
                                        Added Drafting tools Section.
                                        By: Kristoff Rand
                                          mk11
                                          Is anyone aware of a plugin that draws dashed lines in any direction? For purposed of drawing door/window swing direction on door surfaces. Tried TIG's 2D tools but appears I can't draw at an angle...
                                          Marc Kleinmann
                                          SU Pro 2015
                                          Mac & Win
                                          • pbacotP Offline
                                            Yes you can. Draw the edges first. The line style applies the styled line along an edge.
                                            • 3 / 4
