    Customizing toolbars
    5 Posts 3 Posters 405 Views 3 Watching
    • pmolsonP Offline
      pmolson
      Just installed 2014
      want to customize my tool bars...just create a couple with my most used buttons.
      I cant seem to drag the icons off of the existing toolbars onto my new ones like I could in 2013.
      also there is no customize option under view-toolbars
      how i do this? πŸ˜•
      • KrisidiousK Offline
        Krisidious
        I love toolbars... There are a few options Paul. Sometimes a combination of all of them makes life easier.
        1. The native tools can be moved around on custom toolbars made inside of SketchUp with the base system.
          http://help.sketchup.com/en/article/95452
        2. SCF Power Toolbar by CadFather is a custom toolbar system that can be customized to fit your needs. Some of it is not 2014 compliant.
          http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=26789
          http://rhin.crai.archi.fr/rld/plugin_details.php?id=607
        3. Smustard has a custom toolbar plugin Toolbar Builder Pro by Rick Wilson.
          http://www.smustard.com/script/ToolbarBuilderPro
        4. Aerilius has a plugin called Toolbar Editor that is very, very handy. Seems to take a bit to load though.
          http://sketchucation.com/pluginstore?pln=ae_ToolbarEditor
        There is probably more that I'm not remembering or am not aware of. Someone else might come behind me and pick up the slack.
        By: Kristoff Rand
          If you haven't got it already sorted out, you need to leave the Toolbars window open to be able to modify your toolbars. Then you can drag the tools from the original toolbars to your new custom toolbars. Remember to hold Ctrl while dragging to copy the tools over to the new bars.
          • pmolsonP Offline
            pmolson
            Thank you both,
            Dave, That was just the trick I was looking for.
            I may explore some of the options Kristoff mentioned also when i have time...hahahahh time!
              πŸ‘
              Time? What's that? πŸ˜„
              Are you going to come to the meetup?
