    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [REQ] Ctrl+Push pull without internal faces
    21 Posts 6 Posters 899 Views 6 Watching
    • PixeroP Offline
      Pixero
      Is there a tool that works like pressing Ctrl + Pushpull and creating a extrusion, without having the internal faces created?
        What is the end result you're looking for? Why would you use Ctrl+Push/Pull if you don't want to create the face?
        • PixeroP Offline
          Pixero
          I want to construct the edges like when doing ctrl+Pushpull but without the interior faces. (here marked red) This would make it easier to have quad faced models.
            Ah, I see. When I want edges like that without the faces, I use Move/Copy to copy the edges from an end. That makes it simple to evenly distribute the edges along the length, too.
            I'm usually not worried about quad faces but after creating places for folds.
            No inner faces
              Artisan push pull tool
              • cottyC Offline
                cotty
                There is a plugin Remove Inner Faces for
                Removes unwanted internal faces in a selection as a result of using CTRL+PushPull
                my SketchUp gallery
                • PixeroP Offline
                  Pixero
                  Yes I know of these workaround solutions but I would like to have it as a stand alone tool for better workflow. Running a clean up script might erase things you actually want to be kept also.
                    does artisan push/pull not do as you ask?
                      Well, then, use Rich's suggestion. It works fine although I think it is a little slower than my method of copying edges. I don't really consider copying the edges a work around.
                      • PixeroP Offline
                        Pixero
                        Yes, but as it is part of a commercial script it won't suit the workflow I'm trying to create for our firm with lots of users. 😐
                        Buying Artisan for all of them just to get this functionality is not a solution.
                        I'm thinking maybe it's possible to create such a tool.
                        Is there a way of testing for internal faces while doing a pushpull in ruby?
                          Then I think it is best to ask Fredo if his PushPull suite would have such an option.
                          He just about does on toggle of CTRL except he create the face and loop
                          • JQLJ Offline
                            JQL
                            But it does it already Rich.
                            • Normal push pull
                            • Erase original faces
                            • Faces on contours
                            With all the bells and whistles that also come with it...
                            www.casca.pt
                            Visit us on facebook!
                            • KrisidiousK Offline
                              Krisidious
                              You had me excited for a minute... I was hoping for a version that doesn't flip the original push face to a backface. When I create walls and such I always get backfaces on the outside of and on top of walls.
                              By: Kristoff Rand
                                You don't have to create that problem for yourself. πŸ˜‰
                                  @jql
                                  I must admit I tried every tool but missed that combination.
                                  Apologies to Fredo
                                    Krisidious
                                    I don't really see your point Dave. It's not really up/normal that's my problem, but negative push from the front. I pull all my walls up and then push back down for header and door/widow height. I've learned to pull doors and windows up separately to stop this from happening but it increases workflow.
                                    By: Kristoff Rand
                                      @jql
                                      Apologies to Fredo
                                        That's weird?
                                        My reply posted twice with a three hour interval?
                                          Kris, Push/Pull is doing what it should in those cases. Get rid of the floor inside the walls and it won't give you the reversed faces.
                                          I thought you and I went through this a few years back and had you had it all sorted out.
                                            Krisidious
                                            You're thinking of the wrong face. The top face extruding downwards. it's already a front face and when I extrude it (push/pull) it downwards it flips the top face to a back face.
                                            By: Kristoff Rand
                                            • 1 / 2
