    Draw points
    8 Posts 6 Posters 7.5k Views 6 Watching
    • H Offline
      hhenk
      Hello,
      How can i draw (guide)points in Sketchup? Is there a plugin that works for SU 2014? I downloaded a point-plugin but that did not work.
      Regards,
      hhenk
      • cottyC Offline
        cotty
        There is one construction points tool in the projections plugin (Didier Bur).
        my SketchUp gallery
        • BoxB Offline
          There are quite a few plugins for this Tig, Thomthom, Rich O'Brien, Matt666, MattC, Sam D Mitch, Fredo6 just to name a few.
          Something as simple as typing Points into the search function of the PluginStore will find several for you.
            yes please learn to do simple searches...
            But out of those Matt666's PointTool is probably the simplest menu/toolbar - and it will work in all versions of SketchUp...
            http://sketchucation.com/pluginstore?pln=PointTool
            • H Offline
              hhenk
              Thanks, it works this time!
              @Tig, i did some search off corse but it seemed i put the .rb in the wrong folder 😞
              hhenk
                aravinth
                how to download this files πŸ˜•
                  Two posts before yours I posted a link to a plugin in the PluginStore that does this.
                  If you are logged in you can download the RBZ.
                  Then automatically install it using the built-in installer tool.
                  Pre-v2017 = SkechUp > [+Window on PC] Preferences > Extensions > Install extension using gray button...
                  = v2017 = SkechUp > [+Window on PC] Extension Manager > Install extension using red button...
                  If you have earlier than v8M2 then you really ought to update !
                    Fredo tools has one who draw points of existing segments! Can be also useful! πŸ˜‰
