    [Plugin][$] VisuHole - v1.5a - 01 Apr 24
    104 Posts 40 Posters 136.3k Views 39 Watching
    • I Offline
      ivansmirnov333 Newcomers @ivansmirnov333
      @ivansmirnov333 anyone from support is here? Why my stencils aren't save? Every time I have to make the same new ones.
      TIGT Dave RD 2 Replies Last reply Reply Quote 0
      • TIGT Online
        TIG Moderator @ivansmirnov333
        @ivansmirnov333
        Sounds like it might be a permissions issue.
        Perhaps @fredo6 can comment further...
        If you are on a PC installing SketchUp correctly or Repairing it can sometimes fix it - but @fredo6 might want you to delete one of his folders used to store things like templates...
        To effect a SketchUp 'Repair' do the following...
        Close SketchUp.
        Find it's installer exe file [usually in Downloads] or get afresh one downloaded.
        Select the exe file and right-click > context-menu > Run as administrator
        In the dialog that opens choose 'Repair'.
        When it completes restart SketchUp and retest...
        Installing by double clicking the exe file to 'Run' ir is not the same, even if your user-account has admin-powers - it can cause unpredictable issues with folder and file permissions etc...
        A Repair will not adversely affect any customization or installed extensions etc...
          Dave R @ivansmirnov333
          @ivansmirnov333 from the first post in the thread:
          @fredo6 said in [Plugin][$] VisuHole - v1.5a - 01 Apr 24:
          In the current version, Stencils must be picked in the model.
          This implies that your stencils must be present in the model. You could create components of your stencils and save them into a local collection.
            bobvdm
            It's a great app!
            I only have one problem on a certain surface it will not cut rectengular/square holes.
            Only when I rotate them it wil cut a hole.
            Round, oval, diamond whatever shapes seem to work ok.
            Do you have any idea?
            It was the same in al the earlier versions, now using the latest update.
            Many thanks in advance!
            Bob
            VisuHole_NoHole1.mp4
            • 6
            • 6 / 6
