    Reversed Displacement
    renderpluginsextensions
    4 Posts 3 Posters 489 Views 3 Watching
    • F Offline
      frikkiefrikkie
      Reversed Displacement.
      I have inserted a brick & mortar vismat as a new material from sketchup.
      When im rendering, the mortar is protruding from the brick.
      Can the displacement be reversed in a setting or how can I fix this.
      • TedVitale_CGT Offline
        TedVitale_CG
        In the displacement Texture slot there is an invert function. Try inverting the displacement map (see attached). Otherwise, go into the Texture with Photoshop or gimp and invert it there.
        Ted Vitale
        Owner | Creative Director
        http://www.voxl.vision
        • ToboboT Offline
          Tobobo
          Can you post the bump map you are using?
          Toby
          Philippians 4:13
          • F Offline
            frikkiefrikkie
            The 1st post sorted the issue out. Thank you either way.
