    Sketchup 2014 CAD cleanup plugins
    4 Posts 4 Posters 1.6k Views 4 Watching
    • K Offline
      Kenneth R Kuhlman
      It appears there are no CAD Cleanup Plugins or Extensions for Sketchup 2014?
      • mitcorbM Offline
        mitcorb
        Here is one:
        https://extensions.sketchup.com/en/content/cleanup%C2%B3
        Here is another:
        https://extensions.sketchup.com/en/content/edge-tools%C2%B2
        • sfto1S Offline
          sfto1
          I use the following Cad Cleanup type plugins in SU2014
          Delete Coplanar Edges, I think by Chris Fullmer - not sure where I found it. I thought I downloaded it from Sketchucation Plugin Store, but I did not see it there today.
          Edit: Delete Coplanar is by Rick Wilson - found at Smustard.com
          Make Faces by Todd Burch - found at Smustard.com
          Stray Lines by Todd Burch - found at Smustard.com
          The last two I manually placed in the plugin folder. I do not remember where it is located in SU2014 but there are other posts that deal with that issue.
          Good Luck.
          • fredo6F Offline
            fredo6
            You have also EdgeInspector for the small artefacts (and coplanar edges as well).
            Fredo
