    Making an aerogel model?
    renderpluginsextensions
    10 Posts 6 Posters 1.6k Views 6 Watching
    • john2J Offline
      john2
      I want to make a 3d model of an aerogel cuboid. How can I do that in SketchUp?
      • cottyC Offline
        cotty
        You will get more answers if you explain how an aerogel cuboid looks like...
        my SketchUp gallery
        • john2J Offline
          john2
          Well here are the images, how aero gel looks like
          http://p25ext.lanl.gov/people/hubert/aerogel/aerogel_1.gif
          http://boingboing.net/filesroot/200602061740.jpg
          http://upload.wikimedia.org/wikipedia/commons/2/2c/Aerogel_hand.jpg
          • cottyC Offline
            cotty
            The closest you will get only with SU is with using a transparent color for a cube. Otherwise you will need a Renderer to reproduce the sub surface scattering of that material.
            my SketchUp gallery
            • john2J Offline
              john2
              Okay, what is the procedure for that subsurface scattering? That's the tricky thing.
              Sent from my C2305 using Tapatalk
              • xiombargX Offline
                xiombarg
                Subsurface scattering has to do with rendering and not modelling. Basically its how light interacts with semi-transparent objects creating diffusion effects. So what this means is that it doesn't have much to do with how you build your model or with Sketchup directly. It has mostly to do with your rendering software and its settings to get the end result you are looking for.
                • andybotA Offline
                  andybot
                  since you're posting in the vray subsection, I am assuming you'd like pointers on how to render this effect in vray. The simple way would be to add a refraction layer, change your IOR to 1.03 (looks like there is slight refraction, just not as much as glass), and adjust your "fog" intensity and color to where you need it.
                  • TedVitale_CGT Offline
                    TedVitale_CG
                    Try this for just a Sketchup model. In V-Ray you can make a truly realistic version using a Refraction material layer.
                    Just as a side note, the model I've shared wont render properly in V-Ray. Its only an example of how to illustrate aerogel in Sketchup.
                    aerogel cube
                    Ted Vitale
                    Owner | Creative Director
                    http://www.voxl.vision
                    • soloS Offline
                      solo
                      That's pretty good, no need to render πŸ‘
                      http://www.solos-art.com
                      • xiombargX Offline
                        xiombarg
                        Nice solution!
                        At first I thought you were just using a textured cube.
