    How should i fill up hole in a face
    10 Posts 5 Posters 603 Views 5 Watching
    • Y Offline
      YoungOSG
      just like the picture,what should i do to fill up the hole.
      in fact, i do not think its a hole,using Make face isn't helpful
      anyone helps
      ![RV0SA4N6V(L]B$OVI5_ES.jpg](/uploads/imported_attachments/JB1n_RV0SA4N6VLBOVI5_ES.jpg)
      • massimoM Offline
        massimo Moderator
        If the surface is planar, just draw a segment like the picture below.
        ![RV0SA4N6V(L]B$OVI5_ES.jpg](/uploads/imported_attachments/dAE4_RV0SA4N6VLBOVI5_ES.jpg)
        • Y Offline
          YoungOSG
          [attachment=0:3iv5qpo3]<!-- ia0 -->RV0SA4N6V(L]B$OVI5_ES.jpg<!-- ia0 -->[/attachment:3iv5qpo3]
          is there a plugin to fix this problem?
          can i get four vertices to redraw this face?
          • massimoM Offline
            massimo Moderator
            Why you need a plugin to draw a line? Have you tried what I suggested?
            • Y Offline
              YoungOSG
              you are right ,i doesn't need a plugin to draw a line.
              in fact ,my problem is ,like the picture,there are many faces inside the wall ,but i do not need them.
              these faces makes the wall not a solid,and i need to do union.
              is there a way to make the way to be a solid?
              thanks
              ![MMBBO(_5H2NW1LME]4307MD.jpg](/uploads/imported_attachments/mHSL_MMBBO_5H2NW1LME4307MD.jpg)
                Not exactly a solution for fill your volume but...
                when you have somme holes...
                Add faces by TIG
                http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=7085;image
                • massimoM Offline
                  massimo Moderator
                  thanks
                  Ok, that's a different question.
                  How is made the arc? It seems that you started another thread with this question. Have you already tried the suggested solutions?
                  If they don't work post the SKP model here so we can have a look.
                  • cottyC Offline
                    cotty
                    @youngosg said:
                    in fact ,my problem is ,like the picture,there are many faces inside the wall ,but i do not need them. these faces makes the wall not a solid,and i need to do union
                    These lines will not prevent the construction of a solid wall...
                    my SketchUp gallery
                    • Y Offline
                      YoungOSG
                      thanks
                      http://sketchucation.com/forums/viewtopic.php?f=79%26amp;t=58550
                      here is my really question.all i do is want to extract the outer shell.any helps?
                        Why didn't you ask your real question in the first place?
