    Vray 2.0 DR with IES lights problem - sketch up 2014
    renderpluginsextensions
    6 Posts 4 Posters 2.4k Views 4 Watching
      AMELIEBOB
      Hi everyone!
      I'm pretty new at using distributed rendering in Sketchup.
      I'm working at office with a server that every computer has access to. I have a scene mostly lighted with IES lights (wich are all located on that server) and I have nothing on my computer, all my textures are on that server. No problem for the textures.
      Here is the path for textures : "Z:/Sketchup/Vray/Images/Finis intérieurs/Tuiles/XXX.jpg" and path for lights : "Z:/Sketchup/Lights/xxxx.ies"
      I have saved my light cache and irriadiance map files and all machines can access it - no problem.
      My scene looks fine when I render on my machine. (See attached)
      My problem occurs when distribution rendering is on
      When I use both local machine and slaves machines, brighter spots appears where my computer has rendered. Where the slaves machine rendered there is no IES lights. (something like this (http://vray.info/tutorials/vray_distributed_rendering_and_backburner/assets/drbackburner_17.jpg)
      When I render only the slaves machine there is no ied lights either. (See attached)
      But I used the same type of path for all the files in the scene. What am i doing wrong here??
      Please help fast!!
      Thank you, Amelie
      Sketchup 2014 + Vray 2.00.24261
      • TedVitale_CGT Offline
        TedVitale_CG
        Are all your DR Nodes running on the latest version of V-Ray 2.0 as well?
        Ted Vitale
        Owner | Creative Director
        http://www.voxl.vision
          AMELIEBOB
          Yes! all the same version
          • Z Offline
            Zylescozar19
            Im having the same issue.
            and thanks for this thread got an idea how could i figure out whats wrong.
            You just need to copy all the materials on both cpu.
            hope it helps.
              TedVitale_CG
              If you can share the file I'd like to test this out.
              Ted Vitale
                maximarko
                There is a solution for the bright spots. Under Settings/Color mapping tab uncheck "Sub-pixel mapping".
                I don't have an answer for the IES problem. If your copy of V-ray is cracked maybe thats the issue, a bad crack...just saying...
