    Creating a hat brim
    14 Posts 6 Posters 1.1k Views 6 Watching
    • E Offline
      ericschimel
      So here's a challenge: Does anyone have any ideas for repairing this had brim? I've tried with Artisan tools and I haven't had much luck....
      http://note.io/1jqJ1Eh
      -Eric
      http://plugin.sketchthis.net
      Sketchup Kitchen Design Plugin
      Custom Models
      • Rich O BrienR Online
        I'd suggest remaking.
        • E Offline
          ericschimel
          Well, unfortunately that is a 3D scan that I can't do again... That was my first thought though.
          -Eric
          Custom Models
          • olisheaO Offline
            olishea
            You could do it if you had the patience of a saint.
            oli
              Ok.
              Without seeing hidden geometry it is hard to make suggestion.
              Not impossible though
              • xiombargX Offline
                xiombarg
                Use Artisans knife tool to slice off the remaining brim and delete with as few slices as possible and as far out away from the head or top portion of the hat as the case may be. --Try to preserve the front view arc of the brim still attached to the hat-- Extrude out a new brim using Joint Push Pull. Use the knife tool again to add vertices or to trim and delete to get the proper shape. Use Vertex Tools to shape in detail as needed.
                Might want to hide most of the figure at some point when slicing with the knife.
                • xiombargX Offline
                  xiombarg
                  Hope that made sense, I was typing on my phone and trying to give you the short version...
                  This can be done but you have to rebuild the brim, and the easiest way to do this would be to get rid of the broken geometry and simplify the area of where the brim used to be into a small set of surfaces and hopefully still see where the brim used to be --hence using the knife tool.
                  Once you have something that you can extrude out as a new brim, from there it's just a matter of pushing and pulling vertices around to get the shape back to a realistic looking brim.
                  • cottyC Offline
                    cotty
                    Can you share only the broken part (not only the hole πŸ˜„ ) to play with?
                    my SketchUp gallery
                    • E Offline
                      ericschimel
                      I'll give it a try with the knife tool. If anyone wants to take a crack at it, here's the model:
                      https://www.dropbox.com/s/g66rfmkzrlprlc0/Justin%20Reduced.skp
                      -Eric
                      Custom Models
                      • ely862meE Offline
                        ely862me
                        Really simple stuff.. Basically you will create the missing geometry then fit it together, then smooth the connection to make a nice transition.
                        Justin Reduced a.part1.rar
                        Justin Reduced a.part2.rar
                        Elisei (sketchupper)
                        Come and See EliseiDesign
                        • E Offline
                          ericschimel
                          Incredible! How did you do that? With Artisan tools, or did you just break that arc I made up into triangle somehow?
                          -Eric
                          Custom Models
                          • olisheaO Offline
                            olishea
                            looks like some FFD involved too (free form deformation).
                            Great work elisei.
                            oli
                            • ely862meE Offline
                              ely862me
                              Hey there and thanks !
                              Well, I just drew an arc and then I copied it to the other side, then connected the two arcs with Curviloft. After that I used FFD to bring the new surface closer to the old one. Then I connected the parts using the pencil tool. Then I used the Smooth brush(from Artisan) and also I subdivided the connection in order to have better control over it with the Smooth brush . And that should be it.
                              • E Offline
                                ericschimel
                                That is quite impressive! Thanks again, I've learned something new!
                                -Eric
                                Custom Models
