    [Plugin] Deck Builder (Updated 23-Jun-2015)
    56 Posts 19 Posters 53.5k Views 19 Watching
      sdmitch
      In response to
      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=58000.
      SketchUp Plugins | PluginStore | SketchUcation
      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
      (sketchucation.com)
      Update 23-Jun-2014 - Corrected a problem with the Rotation option.
      Update 19-Jun-2014 - Added 3 selectable posts and railing to steps. Fixed deformed post on curved sections.
      With a huge amount of SWAG, I have posted Deck Builder to the Plugin Store.
      Please do not assume that this plugin produces anything that is code compliant. It is merely my attempt to provide a visual and nothing more.
      Choose Plugins>SDM Tools>Face Tool>Deck Builder to execute the plugin.
      Select the sizes you wish for the decking and joists. Since the decking is oriented parallel to the longest edge, you can choose 90 rotation if that is not desired.
      Three simple spindles and posts are included with the plugin. You are free to make and add your own to the DB_Support_Files sub-directory. The spindles must be 24" high and the posts 36" high. Both should be oriented vertically with the bottom center at the model origin.
      All options that are checked will be created when the face is selected. Any option that don't want should be un-checked. The posts/supports are created at the end of each face edge and are required if you want a railing. The steps, if checked, are placed on the shortest edge that is at least 24" long. That edge can be located anywhere on the face.
      http://sdmitch.blogspot.com/
      • P Offline
        Thanks for getting your deck extension out there!
          solo
          Damn! this is a brilliant tool, thanks a ton.
          http://www.solos-art.com
            TECHDAVE02
            LOOKS! Great but I can't get the web-dialog to come up?
            Frame-It works but alas no Deck - Builder
              mwm5053
              🎉 this so cool Thanks sdmitch
              2011 iMac
              SU 2015 Pro, 2017 Make
              V2 Twilight
              macOS Sierra 10.12.5
                Did you trying quitting and restarting SketchUp after installing it?
                • K Offline
                  Krisidious
                  Thanks sdmitch, this is a great time saver. As for code compliant, that it builds it close enough works just fine, then adjustments can be made for compliance.
                  Would it be possible to create the same sub directories for posts and rails?
                  By: Kristoff Rand
                    TECHDAVE02
                    [ Dave R]"Did you trying quitting and restarting SketchUp after installing it?"
                    Yes and rebooted computer as well
                    • K Offline
                      Krisidious
                      did you go to the extensions area and do the install? Do you not see deckbuilder at all in the sdm menu?
                      By: Kristoff Rand
                        TECHDAVE02
                        Yes it is there but no luck and as stated the Frame-It works fine
                        • K Offline
                          Krisidious
                          Do you use internet explorer? dump your cookies and cache from IE.
                          By: Kristoff Rand
                            TECHDAVE02
                            Thanks again; did it no luck. "sdmitch" has my error message hopefully some resolution soon.
                              sdmitch
                              The problem is not yours, it's mine. I stupidly created and saved the components in V14 format which V8 or V13 cant handle.
                              If you are a non-V14 user wait until I update the post before downloading the plugin.
                                sdmitch
                                A new copy of the Deck_Builder.rbz file has been uploaded to the Plugin Store. If you are a V8 or a V13 user, please download a new copy of the file and re-install.
                                • P Offline
                                  Excellent! 😎
                                  Of course with Random Painter by Chris Fullmer! ☀
                                  Amazing that you can choose any "horizontal !" surface! 😲
                                    jolran
                                    Well done!
                                    • U Offline
                                      utiler
                                      Sam, you're really coming up with some great time savers!!
                                      I've always thought a handrail / fence plugin would be neat. Haven't tried this deck builder plugin yet but IMO, a deck builder tool should be for the deck and a railing plugin should be what you use next....
                                      Would work off centre lines, select start point and trace around the profile of the railing then input post [square or round], size and height then spacing along the same lines and what you've done here.....
                                      Love seeing your work, mate!
                                      Just Curious...
                                        sdmitch
                                        Update 19-Jun-2014 - Added 3 selectable posts and railing to steps. Fixed deformed posts on curved sections.
                                          alpro
                                          sdmitch, great plugin, last version worked well for me except on curves, this new version doesn't work for me at all, no matter how I draw the face when I execute the plugin, it hangs for a bit then just reverses the face. Windows 7, IE 11, Sketchup 2014 Pro
                                          Mike
                                            sdmitch
                                            Mike
                                            If the face is reversed, the plugin has at least partially ran so run it with the Ruby Console open and see where and/or what is causing it to fail.
                                            There was a change in the folder where the posts and spindles are so, if you only copied the new plugin to the Plugins folder instead of doing the normal extensions install, that could be the problem.
                                            • 1 / 3
