    [Plugin] Deck Builder (Updated 23-Jun-2015)
    56 Posts 19 Posters 55.6k Views 19 Watching
    • T
      TECHDAVE02
      LOOKS! Great but I can't get the web-dialog to come up?
      Frame-It works but alas no Deck - Builder
        mwm5053
        🎉 this so cool Thanks sdmitch
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
          Did you trying quitting and restarting SketchUp after installing it?
          • KrisidiousK
            Krisidious
            Thanks sdmitch, this is a great time saver. As for code compliant, that it builds it close enough works just fine, then adjustments can be made for compliance.
            Would it be possible to create the same sub directories for posts and rails?
            By: Kristoff Rand
            • T
              TECHDAVE02
              [ Dave R]"Did you trying quitting and restarting SketchUp after installing it?"
              Yes and rebooted computer as well
              • KrisidiousK
                Krisidious
                did you go to the extensions area and do the install? Do you not see deckbuilder at all in the sdm menu?
                By: Kristoff Rand
                • T
                  TECHDAVE02
                  Yes it is there but no luck and as stated the Frame-It works fine
                  • KrisidiousK
                    Krisidious
                    Do you use internet explorer? dump your cookies and cache from IE.
                    By: Kristoff Rand
                    • T
                      TECHDAVE02
                      Thanks again; did it no luck. "sdmitch" has my error message hopefully some resolution soon.
                      • sdmitchS
                        sdmitch
                        The problem is not yours, it's mine. I stupidly created and saved the components in V14 format which V8 or V13 cant handle.
                        If you are a non-V14 user wait until I update the post before downloading the plugin.
                        http://sdmitch.blogspot.com/
                        • sdmitchS
                          sdmitch
                          A new copy of the Deck_Builder.rbz file has been uploaded to the Plugin Store. If you are a V8 or a V13 user, please download a new copy of the file and re-install.
                            Excellent! 😎
                            Of course with Random Painter by Chris Fullmer! ☀
                            Amazing that you can choose any "horizontal !" surface! 😲
                            • jolranJ
                              jolran
                              Well done!
                              • utilerU
                                utiler
                                Sam, you're really coming up with some great time savers!!
                                I've always thought a handrail / fence plugin would be neat. Haven't tried this deck builder plugin yet but IMO, a deck builder tool should be for the deck and a railing plugin should be what you use next....
                                Would work off centre lines, select start point and trace around the profile of the railing then input post [square or round], size and height then spacing along the same lines and what you've done here.....
                                Love seeing your work, mate!
                                Just Curious...
                                • sdmitchS
                                  sdmitch
                                  Update 19-Jun-2014 - Added 3 selectable posts and railing to steps. Fixed deformed posts on curved sections.
                                    alpro
                                    sdmitch, great plugin, last version worked well for me except on curves, this new version doesn't work for me at all, no matter how I draw the face when I execute the plugin, it hangs for a bit then just reverses the face. Windows 7, IE 11, Sketchup 2014 Pro
                                    Mike
                                    • sdmitchS
                                      sdmitch
                                      Mike
                                      If the face is reversed, the plugin has at least partially ran so run it with the Ruby Console open and see where and/or what is causing it to fail.
                                      There was a change in the folder where the posts and spindles are so, if you only copied the new plugin to the Plugins folder instead of doing the normal extensions install, that could be the problem.
                                        Very cool! ☀
                                        http://s6.postimg.org/z36g1n8pd/deck1.jpg
                                          Here maybe a little glitch! 😉
                                          I made any regulates!
                                          http://s6.postimg.org/3kuxyptqp/deck_glitch.jpg
                                          deckglitch.skp
                                          • sdmitchS
                                            sdmitch
                                            The quality control director has been fired for not sufficiently testing in metric units.
                                            Problem has been fixed. Maybe.
                                            • 1 / 3
