    [Plugin] Deck Builder (Updated 23-Jun-2015)
    56 Posts 19 Posters 55.0k Views 19 Watching
    • KrisidiousK Offline
      Krisidious
      Thanks sdmitch, this is a great time saver. As for code compliant, that it builds it close enough works just fine, then adjustments can be made for compliance.
      Would it be possible to create the same sub directories for posts and rails?
      By: Kristoff Rand
        TECHDAVE02
        [ Dave R]"Did you trying quitting and restarting SketchUp after installing it?"
        Yes and rebooted computer as well
          Krisidious
          did you go to the extensions area and do the install? Do you not see deckbuilder at all in the sdm menu?
          By: Kristoff Rand
            TECHDAVE02
            Yes it is there but no luck and as stated the Frame-It works fine
              Krisidious
              Do you use internet explorer? dump your cookies and cache from IE.
              By: Kristoff Rand
                TECHDAVE02
                Thanks again; did it no luck. "sdmitch" has my error message hopefully some resolution soon.
                • sdmitchS Offline
                  sdmitch
                  The problem is not yours, it's mine. I stupidly created and saved the components in V14 format which V8 or V13 cant handle.
                  If you are a non-V14 user wait until I update the post before downloading the plugin.
                  http://sdmitch.blogspot.com/
                  • sdmitchS Offline
                    sdmitch
                    A new copy of the Deck_Builder.rbz file has been uploaded to the Plugin Store. If you are a V8 or a V13 user, please download a new copy of the file and re-install.
                      Excellent! 😎
                      Of course with Random Painter by Chris Fullmer! β˜€
                      Amazing that you can choose any "horizontal !" surface! 😲
                      • jolranJ Offline
                        jolran
                        Well done!
                        • utilerU Offline
                          utiler
                          Sam, you're really coming up with some great time savers!!
                          I've always thought a handrail / fence plugin would be neat. Haven't tried this deck builder plugin yet but IMO, a deck builder tool should be for the deck and a railing plugin should be what you use next....
                          Would work off centre lines, select start point and trace around the profile of the railing then input post [square or round], size and height then spacing along the same lines and what you've done here.....
                          Love seeing your work, mate!
                          Just Curious...
                          • sdmitchS Offline
                            sdmitch
                            Update 19-Jun-2014 - Added 3 selectable posts and railing to steps. Fixed deformed posts on curved sections.
                              alpro
                              sdmitch, great plugin, last version worked well for me except on curves, this new version doesn't work for me at all, no matter how I draw the face when I execute the plugin, it hangs for a bit then just reverses the face. Windows 7, IE 11, Sketchup 2014 Pro
                              Mike
                              • sdmitchS Offline
                                sdmitch
                                Mike
                                If the face is reversed, the plugin has at least partially ran so run it with the Ruby Console open and see where and/or what is causing it to fail.
                                There was a change in the folder where the posts and spindles are so, if you only copied the new plugin to the Plugins folder instead of doing the normal extensions install, that could be the problem.
                                  Very cool! β˜€
                                  http://s6.postimg.org/z36g1n8pd/deck1.jpg
                                    Here maybe a little glitch! πŸ˜‰
                                    I made any regulates!
                                    http://s6.postimg.org/3kuxyptqp/deck_glitch.jpg
                                    deckglitch.skp
                                    • sdmitchS Offline
                                      sdmitch
                                      The quality control director has been fired for not sufficiently testing in metric units.
                                      Problem has been fixed. Maybe.
                                        alpro
                                        sdmitch, installed latest version through Sketchucation Plugin Store, here is what shows in the ruby console when executing the plugin.
                                        Error: #<TypeError: no implicit conversion from nil to integer>
                                        C:/Users/MRacz/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Deck Builder.rb:362:in []' C:/Users/MRacz/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Deck Builder.rb:362:in add_posts'
                                        C:/Users/MRacz/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Deck Builder.rb:218:in `onLButtonDown'
                                        Thanks for your help.
                                        Mike
                                        Just checked my plugins folder, for some reason neither a spindles or post folder was created, weird.
                                        Nevermind, folder was created and after trying again, deck builder works as advertised, even weirder
                                          Mike, I would try reinstalling it. I just installed the current version on my PC via the SCF Plugin Store and don't see the error when starting SketchUp fresh.
                                          • BoxB Offline
                                            Can you have a look at the toolbar settings, it seems you have it set to open the toolbar every time SU starts. So even if you have closed the toolbar it will reinitialize at the next start up. Slightly annoying.
                                            • 1 / 3
