    [Plugin] Deck Builder (Updated 23-Jun-2015)
    56 Posts 19 Posters 56.5k Views 19 Watching
    • KrisidiousK
      Krisidious
      did you go to the extensions area and do the install? Do you not see deckbuilder at all in the sdm menu?
      By: Kristoff Rand
      • T
        TECHDAVE02
        Yes it is there but no luck and as stated the Frame-It works fine
        • KrisidiousK
          Krisidious
          Do you use internet explorer? dump your cookies and cache from IE.
          By: Kristoff Rand
          • T
            TECHDAVE02
            Thanks again; did it no luck. "sdmitch" has my error message hopefully some resolution soon.
            • sdmitchS
              sdmitch
              The problem is not yours, it's mine. I stupidly created and saved the components in V14 format which V8 or V13 cant handle.
              If you are a non-V14 user wait until I update the post before downloading the plugin.
              http://sdmitch.blogspot.com/
              • sdmitchS
                sdmitch
                A new copy of the Deck_Builder.rbz file has been uploaded to the Plugin Store. If you are a V8 or a V13 user, please download a new copy of the file and re-install.
                  Excellent! 😎
                  Of course with Random Painter by Chris Fullmer! β˜€
                  Amazing that you can choose any "horizontal !" surface! 😲
                  • jolranJ
                    jolran
                    Well done!
                    • utilerU
                      utiler
                      Sam, you're really coming up with some great time savers!!
                      I've always thought a handrail / fence plugin would be neat. Haven't tried this deck builder plugin yet but IMO, a deck builder tool should be for the deck and a railing plugin should be what you use next....
                      Would work off centre lines, select start point and trace around the profile of the railing then input post [square or round], size and height then spacing along the same lines and what you've done here.....
                      Love seeing your work, mate!
                      Just Curious...
                      • sdmitchS
                        sdmitch
                        Update 19-Jun-2014 - Added 3 selectable posts and railing to steps. Fixed deformed posts on curved sections.
                          alpro
                          sdmitch, great plugin, last version worked well for me except on curves, this new version doesn't work for me at all, no matter how I draw the face when I execute the plugin, it hangs for a bit then just reverses the face. Windows 7, IE 11, Sketchup 2014 Pro
                          Mike
                          • sdmitchS
                            sdmitch
                            Mike
                            If the face is reversed, the plugin has at least partially ran so run it with the Ruby Console open and see where and/or what is causing it to fail.
                            There was a change in the folder where the posts and spindles are so, if you only copied the new plugin to the Plugins folder instead of doing the normal extensions install, that could be the problem.
                              Very cool! β˜€
                              http://s6.postimg.org/z36g1n8pd/deck1.jpg
                                Here maybe a little glitch! πŸ˜‰
                                I made any regulates!
                                http://s6.postimg.org/3kuxyptqp/deck_glitch.jpg
                                deckglitch.skp
                                • sdmitchS
                                  sdmitch
                                  The quality control director has been fired for not sufficiently testing in metric units.
                                  Problem has been fixed. Maybe.
                                    alpro
                                    sdmitch, installed latest version through Sketchucation Plugin Store, here is what shows in the ruby console when executing the plugin.
                                    Error: #<TypeError: no implicit conversion from nil to integer>
                                    C:/Users/MRacz/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Deck Builder.rb:362:in []' C:/Users/MRacz/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Deck Builder.rb:362:in add_posts'
                                    C:/Users/MRacz/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Deck Builder.rb:218:in `onLButtonDown'
                                    Thanks for your help.
                                    Mike
                                    Just checked my plugins folder, for some reason neither a spindles or post folder was created, weird.
                                    Nevermind, folder was created and after trying again, deck builder works as advertised, even weirder
                                      Mike, I would try reinstalling it. I just installed the current version on my PC via the SCF Plugin Store and don't see the error when starting SketchUp fresh.
                                      • BoxB
                                        Can you have a look at the toolbar settings, it seems you have it set to open the toolbar every time SU starts. So even if you have closed the toolbar it will reinitialize at the next start up. Slightly annoying.
                                        • sdmitchS
                                          sdmitch
                                          If you don't want the toolbar to show on start up find this line
                                          	cmd.tooltip="Deck Builder";tb.add_item cmd;tb.show
                                          and replace it with this line
                                          	cmd.tooltip="Deck Builder";tb.add_item cmd;#tb.show
                                          The Toolbar will be created but not automatically displayed.
                                          • BoxB
                                            Thanks for that, it certainly works. I would have thought it would be the default setting, after all if you turn it off you would expect it to stay turned off.
                                            • 1 / 3
