    Grass shader
    renderpluginsextensions
    4 Posts 4 Posters 405 Views 4 Watching
      samuray12222
      Hi! I have problem with grass shader, it makes squares.Look at pictures.
      Please help. Thank you
      grass shader
      the same grass shader
      • andybotA Offline
        andybot
        This thread should help explain how to properly use displacement:
        http://sketchucation.com/forums/viewtopic.php?f=322%26amp;t=28593
        • V Offline
          valerostudio
          If you have 2.0 I would use proxies and stay clear of displ grass.
          • TedVitale_CGT Offline
            TedVitale_CG
            This may also have to do with image resolution. If your image is noticeably tiled, than your grass displacement will look tiled as well.
            Ted Vitale
            Owner | Creative Director
            http://www.voxl.vision
