    Moving plugins from 2013 to 2014 on Mac
    4 Posts 3 Posters 242 Views 3 Watching
      skeerc
      Hi, Having just installed 2014 Pro I went to move "all" my plugins from 2013 Pro to 2014 Pro using the allocated directory Plugin folders for each version but this does not work. The folders are now located differently on my iMac 10.8.5. Is it possible to transfer 20 - 30 plugins at once or do they all have to be re-installed via Sketchup Tools 2.6 & SketchUcation Plugins manager?
        Use the Bundles feature in SketchUcation Tools to sync your installs to the new version
          skeerc
          Hi Rich, thanks for the input, could you direct me to a link or if there's a relevant tutorial for this with more information, I have viewed the tutorials you've recently released but I'm still not having much success with the transfer. Do I have to create a separate folder in a new location or can I direct to the current 2013 Pro plugins folder, also is the Bundles feature part of SketchUcation Plugins Manager > Manage Sets > Import. I'm getting extensive loading errors from the restart, so obviously doing something incorrect.
            This has been covered repeatedly here on SCF. You shouldn't just copy plugins from SU2013 to the SU2014 installation. Many plugins required updates to meet Ruby 2.0 standards. Probably the best thing you could do is delete the plugins you pasted into the the SU2014 Plugins folder and start from scratch. Using the SCF Plugin Store's tools will make that easier.
