    Deleting vertices - req. help
    4 Posts 3 Posters 2.7k Views 3 Watching
      mrjumpmanv2
      Apologies if this is in the wrong area, sketchucation format has changed since i last visited.
      Basically my question is how do you delete stray vertices along a line? I have quite a few (100+) stray vertices in my entire mesh and i don't have time to use the move tool or erase every line and retrace it. Is there a simple workaround or script that anyone knows about?
      Normally this wouldn't be an issue but the model i'm trying to make has to be subdivided so the extra vertices cause quite a mess.
      Regards,
      Christian
      %(#000040)["Anyone who has never made a mistake has never tried anything new."
      Albert Einstein]
        Jim
        Look for ThomThom's Cleanup plugin on the Extensions Warehouse or Plugins Store.
          mrjumpmanv2
          thanks!
          Albert Einstein]
            Fredo also has 'Remove Lonely Vertices'...
            http://sketchucation.com/forums/viewtopic.php?p=332047#p332047
            Which is part of 'FredoTools'...
            http://sketchucation.com/pluginstore?pln=FredoTools
