Deleting vertices - req. help
Apologies if this is in the wrong area, sketchucation format has changed since i last visited.
Basically my question is how do you delete stray vertices along a line? I have quite a few (100+) stray vertices in my entire mesh and i don't have time to use the move tool or erase every line and retrace it. Is there a simple workaround or script that anyone knows about?
Normally this wouldn't be an issue but the model i'm trying to make has to be subdivided so the extra vertices cause quite a mess.
Regards,
Christian
Look for ThomThom's Cleanup plugin on the Extensions Warehouse or Plugins Store.
thanks!
Fredo also has 'Remove Lonely Vertices'...
http://sketchucation.com/forums/viewtopic.php?p=332047#p332047
Which is part of 'FredoTools'...
http://sketchucation.com/pluginstore?pln=FredoTools
