    Stained glass from a texture
    4 Posts 3 Posters 407 Views 3 Watching
      Matheos
      Is there a way I can render a texture from a image as stained glass? I;ve tried without succes. When I make a window and I attach simply a color, Podium renders the color good. But when I use a image as texture and give it transparency, it renders white. No colors. What did I do wrong?
      • soloS Offline
        solo
        I'm not a Podium user however I'd check the face orientation or to be safe paint both sides with that texture
        http://www.solos-art.com
          Matheos
          I've painted both sides with that texture but the results are still white, not colored
            Give your glass a real thickness.
            View it in Monochrome mode with a Style that uses a distinctive back_face color.
            If any back face looks outwards, select that face, and use the Reverse... context-menu tool.
            Now apply your 'stained-glass' textured-material to the faces as needed.
            You then need to ensure that this material is correctly configured and applied in the Podium Materials editor...
            Then try Podium again...
