Stained glass from a texture
Is there a way I can render a texture from a image as stained glass? I;ve tried without succes. When I make a window and I attach simply a color, Podium renders the color good. But when I use a image as texture and give it transparency, it renders white. No colors. What did I do wrong?
I'm not a Podium user however I'd check the face orientation or to be safe paint both sides with that texture
I've painted both sides with that texture but the results are still white, not colored
Give your glass a real thickness.
View it in Monochrome mode with a Style that uses a distinctive back_face color.
If any back face looks outwards, select that face, and use the Reverse... context-menu tool.
Now apply your 'stained-glass' textured-material to the faces as needed.You then need to ensure that this material is correctly configured and applied in the Podium Materials editor...
Then try Podium again...
