    [Plugin] DrawAlong - v1.2a - 12 Oct 14
    32 Posts 15 Posters 36.2k Views 15 Watching
    • fredo6F Offline
      fredo6
      @pbacot said:
      That's right. The long hand version is usually 5'-2 1/2", but the hyphen is often dropped. So Ruby treats it differently?
      Less and less clear
      in the Ruby console
      a = "5'-2 1/4".to_l
      -8.8976377952756
      Anyway, whatever is the notation, I still don't understand why 5'2 1/4 = 138.74 inches, whereas 5' is just 60 inches.
      Fredo
      • fredo6F Offline
        fredo6
        I found the explanation finally.
        The model was in unit "decimal" metre
        So if you type 5'2 1/4 it is misinterpreted by SU. I guess it takes the 1/4 for 1/4 of a metre.
        Anyway, if the model unit is Fractional, then it works and the 3 notations below would give 62.25 inches
        • 5'2 1/4
        • 5' 2 1/4
        • 5' 2.25"
        I have done the changes and will republish soon
        Fredo
        • fredo6F Offline
          fredo6
          NEW RELEASE: DrawAlong v1.0b - 17 May 14
          DrawAlong 1.0b is an update fixing a bug in the input of architectural units in the VCB. It also includes a Spanish translation (ES) by Oxer.
          It is published as part of FredTools 1.9b.
          See main post of this thread and FredoTools for download.
          Fredo
            Thanks Fredo
            • fredo6F Offline
              fredo6
              NEW RELEASE: DrawAlong v1.1a - 18 Jun 14
              DrawAlong 1.1a is an update fixing various problems and introducing inferences when drawing on a plane (ES) by Oxer.
              It is published as part of FredTools 2.0a.
              Fredo
                makiboypogi
                Very Nice GOD Bless you more... You help thousands of people.
                  chrismichaelgentile
                  This would be great if it included the arc command!
                  • fredo6F Offline
                    fredo6
                    NEW RELEASE: DrawAlong v1.2a - 12 Oct 14
                    DrawAlong 1.2a is an update fixing problems with Construction Points: inferencing when cpoint is on a face and avoid doubling when drawing in Guide mode.
                    It is published as part of FredTools 2.1a.
                    Fredo
                      laudhi
                      πŸ‘
                      • sicksickisckS Offline
                        sicksickisck
                        This is incredible tool.
                        • F Offline
                          function
                          Is it possible to have length snapping with DrawAlong? I can't seem to have it working . . .
                          • F Offline
                            FlorinAp
                            In SU 2024, in a newly created and empty file, the first line (even formed from multiple edges) is not visible, only the second is visible, or if the file is not empty.
                            I tested in SU 2023 and 2022, and this bug is only in 2024.
                            Edit: It is a problem in my custom template that occurs only in SU 2024...!
                            The problem doesn't exist with the same template in SU 2022 or 2023... I don't understand yet...
                            • 2 / 2
