    Keyboard shortcuts and 3d Mouse Pro
    9 Posts 4 Posters 716 Views 4 Watching
      mwm5053
      I've used my 3d Mouse Pro for some time now that I won from here at SCF and really liked it but I use a lot shortcuts for things like show hidden and the regular shortcuts that SU comes with. So in many ways you need three hands one on the regular mouse and one on the keyboard and one on the 3D mouse. All that said I started mapping the 3D mouse buttons for my keyboard shortcuts like undo and previous view and show hidden and want a shortcut to show Large toolset and use The V key but when I go to shortcuts in preferences and type V it changes all View/Tool Palettes/Large Tool set it changes all my plugins to V. Hey SU team can you fix this or maybe a workaround.
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        mwm5053
        And one more thing using modifier keys like command and option aren't allowed. I'm on a Mac by the way.
        2011 iMac
        V2 Twilight
        • BoxB Offline
          Perhaps you missed this post in this thread.
          http://sketchucation.com/forums/viewtopic.php?f=72%26amp;t=57492%26amp;p=524085#p523929
            Why aren't command and option allowed? Is that because you're trying to map keys that aren't on the normal keyboard?
            My use of keyboard shortcuts and not having is why I didn't like having another controller. The basic mouse for the standard zoom, orbit and pan work best for me.
              mwm5053
              Thanks Box and Dave the situation came about when I changed View Large tool set to V all the Views changed.
              2011 iMac
              V2 Twilight
                That's kind of odd. I wonder if you can delete the shortcuts plist and start over? Will that help?
                  mwm5053
                  Will try after a couple hours got to go to church now
                  2011 iMac
                  V2 Twilight
                    mwm5053
                    I only found 2 plist for SketchUp 2014 and deleted them and emptied trash. Still the same, really no big deal just thought it was peculiar I noticed it changed all the View Tools below the Warehouse.
                    2011 iMac
                    V2 Twilight
                    • wind-borneW Offline
                      wind-borne
                      That palette issue within SU since day 1 for me, easy workaround in System Preferences. Does need modifier keys though. Can toggle all the different toolbars...plus your shortcuts show in menu in case your memory slips 😮
                      I would be surprised if you can't use modifiers for keystrokes with that exotic mouse.
                      "To read between the lines was easier than to follow the text."OSX 10.11.6
                      %(#BF80BF)[SU 8 pro
