    Draping question
    4 Posts 2 Posters 359 Views 2 Watching
    • P Offline
      peebo22
      I draped these edges to the TIN-mesh and my question is, can I somehow remove them if I want or are they now connected to the mesh? Because when i try to remove one edge, mesh breaks.
      Is there a possibility to make them as group?
      http://i61.tinypic.com/2dim88i.jpg
        When you Sandbox Drape geometry the receiving container is modified with new intersecting geometry/edges.
        So the draped form is then an integral part of the mesh.
        To keep 'draped' edges separated from the mesh you need to look at something like my ExtrudeEdgesByVectorToObject.
        [Part of my Extrude Tools set http://sketchucation.com/pluginstore?pln=ExtrudeTools ]
        Select then extrude the draped-object's faces/edges down in blue [z] axis [use Shift to constrain], pick well below the mesh and the extrusion will be trimmed back at the mesh surface.
        You then need to leave the extrusion within its group, edit that and select/delete [by fence] to leave just the edges lying on the mesh-surface...
        Then you will have a draped set of edges overlaying the mesh but not combined with it at all... πŸ€“
        • P Offline
          peebo22
          Thanks for answer, but I don't think it's a good way...
          It's too heavy, so Sketchup crashes.
          I tried one small lake/pond with your instructions (moved it down with z), but I don't think this will work...or I didn't understand.
          http://i61.tinypic.com/345mqm0.jpg
          It looks nice with normal drape, but it's sad that they are not own group.
          http://i58.tinypic.com/35mr2nb.jpg
            You must delete unwanted vertical faces [by fence] ?
