    How to set bed canopy veil material?!!
    renderpluginsextensions
    3 Posts 2 Posters 994 Views 2 Watching
      sketchuh
      hi you all,
      i wanted to make a see thru veil material for vray sketchup. i know it's possible to have see thru effect using two sided material. my concern is how to show the texture in those veil. see ref pics.
      please help.
      i want to show some of the texture. the detail part.
      is it possible to show the holes in vray sketchup render???
      • TedVitale_CGT Offline
        TedVitale_CG
        Try using a V-Ray 2 Sided material. First create the veil material as a Standard Material, then Create your 2-Sided material. Add your Veil material you just made to both slots of the two sided material, and then change the color to a light grey (the color on your 2-sided material controls the transparency, white is transparent, black is opaque). This should give you the result you're looking for.
        Ted Vitale
        Owner | Creative Director
        http://www.voxl.vision
          sketchuh
          i figured setting the transparency value of the diffuse to 0 use a bitmap for the mask effect. it works.
          yea, i think the 2 sided material will make the material even better. thanks for the help
