    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 394.6k Views 109 Watching
      djrique
      Upload .Rb file PT-BR Language: https://drive.google.com/file/d/0BwqiSt9yjVQDVHZCM1JCOS1wb0U/edit?usp=sharing
      i don´t know to create .rbz file... 😳
      THX.
      • sdmitchS Offline
        sdmitch
        THX.
        An .rbz file is just a .zip file with the extension changed to .rbz
        http://sdmitch.blogspot.com/
        • Mistro11M Offline
          Mistro11
          Hope this render reflects my gratitude. 👍
          i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
          Structural Integrity is Not Just Physical...It's in the Design and Purpose
          • sdmitchS Offline
            sdmitch
            It's beautiful. Thanks for making me look so good.
              sidewalk
              Excellent plugin! A tool like this has been on my wishlist for years.
              One suggestion: Is it possible to add an exterior clapboard/lap siding setting? The parameters could be very similar to the wood setting.
                toto ete
                great plugin! super work and thanks for sharing it!
                keep up the wonderful work!
                • PixeroP Offline
                  Pixero
                  Suddenly I get the same error as mentioned above.
                  When I change pattern the window closes.
                  I've re installed the latest version and tried it on two PCs.
                  Weird. 😕
                  • sdmitchS Offline
                    sdmitch
                    Weird. 😕
                    That makes no sense at all. Have you installed any new plugins lately? Maybe there is a conflict. Does the Ruby Console show any errors?
                    • PixeroP Offline
                      Pixero
                      Here is what the console reports:
                      Error; #<NoMethodError; undefined method `to_l' for nil;NilClass>
                      C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;93;in `dialog'
                      C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;67;in `initialize'
                      C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;34;in `new'
                      C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;34;in `block in <top (required)>'
                      -e;1;in `call'
                      As a side note, would it be possible to have a setting for bevel size?
                      Like if I want half or even a quarter of the size of the bevel.
                      And some min and max distance of the random imperfections?
                      I think both are a litte too big for most cases.
                      • sdmitchS Offline
                        sdmitch
                        > -e;1;in `call'
                        The error is occurring when the defaults are being read so use the "Reset" option first and hopefully that will clear up the problem.
                        I will consider your request as time permits.
                          Mra
                          I think there is a bug in the newest verision. On a rectangle it was complaining about non planar faces, even though this was off a box with sketchup box primitive.
                          Reverting back a version, I was then able to generate a wooden pattern on the same object.
                          • sdmitchS Offline
                            sdmitch
                            I have experienced the same problem with wood on vertical faces. I can't imagine why but will try to sort it out.
                            Thanks for the heads up
                            • sdmitchS Offline
                              sdmitch
                              Problem has been fixed. 💚 Quality control and testing director has been severely punished. 🤢
                                Mra
                                No problem. Thank YOU for such a cool plugin. Can't release images now, but having fun decorating inside of a cafe with wooden panels everywhere. I recommend everyone your plugins.
                                • deaneauD Offline
                                  deaneau
                                  Hello,
                                  i would design a special ground with your plugin
                                  here 3 pictures
                                  is this possible with your plugin?
                                  Translation for the picture
                                  A: Big Corner Part
                                  B: Sidewalk Main Part
                                  C Small Corner Part
                                  😧 Bishop's cap
                                  measure in cm
                                  25cm=9.8425in
                                  35cm=13.7795in
                                  49,5cm=19.4881in
                                  Gap 1cm=0.3937in
                                  This is a part of a typical sidewalk in Berlin
                                  here a german wiki page
                                  http://de.wikipedia.org/wiki/Pflaster_(Belag
                                  Thank you
                                  Dean
                                  MADE, BORN AND LIVING IN BERLIN
                                  Big Thank You to all Programmers
                                  Some German words are so long that they have a perspective. M.Twain
                                  • sdmitchS Offline
                                    sdmitch
                                    It might be possible, in part at least, for a perfect size face but doubtful for a random size face. I'll see what I can do.
                                    • deaneauD Offline
                                      deaneau
                                      that would be great,
                                      if you need a sketchup file i can send this via PM
                                      can i use this in a curve,too?
                                      thank you dean
                                      • sdmitchS Offline
                                        sdmitch
                                        thank you dean
                                        Please do. I hate trying to guess.
                                        • deaneauD Offline
                                          deaneau
                                          Suggestion for different Texture Packs.
                                          what do you think about different texture pack.
                                          in the texture folder i have different folders with diferent textures.
                                          this could be selected via dropdown.
                                          thank you Dean
                                          • deaneauD Offline
                                            deaneau
                                            Hallo is this possible?
                                            green arrows mean only this direction(s) i want
                                            selected multiple face doing this in one step
                                            here what i have choose in preferences
                                            the wall in the backbround is a curved object.
                                            the result is this
                                            reason could be that a curved face is splitted in smaller face like this
                                            the wall part i want produce have an exact width of 1200mm (3' 11")
                                            or have anybody an other solution?
                                            download this file here
                                            Page Not Found
                                            Web word processing, presentations and spreadsheets
                                            (drive.google.com)
                                            the curved face havn´t the exaxt width 😕
                                            thank you
                                            • 6
                                            • 7
                                            • 8
                                            • 16
                                            • 17
                                            • 6 / 17
