    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 461.3k Views 109 Watching
      djrique
      Thank you guy for that great plugin. I'm a brazilian and translated it for portuguese. Do you think that it's good?
      • sdmitchS
        sdmitch
        Good by me.
        http://sdmitch.blogspot.com/
          djrique
          Upload .Rb file PT-BR Language: https://drive.google.com/file/d/0BwqiSt9yjVQDVHZCM1JCOS1wb0U/edit?usp=sharing
          i don´t know to create .rbz file... 😳
          THX.
          • sdmitchS
            sdmitch
            THX.
            An .rbz file is just a .zip file with the extension changed to .rbz
            • Mistro11M
              Mistro11
              Hope this render reflects my gratitude. 👍
              Structural Integrity is Not Just Physical...It's in the Design and Purpose
              • sdmitchS
                sdmitch
                It's beautiful. Thanks for making me look so good.
                  sidewalk
                  Excellent plugin! A tool like this has been on my wishlist for years.
                  One suggestion: Is it possible to add an exterior clapboard/lap siding setting? The parameters could be very similar to the wood setting.
                  • T
                    toto ete
                    great plugin! super work and thanks for sharing it!
                    keep up the wonderful work!
                    • PixeroP
                      Pixero
                      Suddenly I get the same error as mentioned above.
                      When I change pattern the window closes.
                      I've re installed the latest version and tried it on two PCs.
                      Weird. 😕
                      • sdmitchS
                        sdmitch
                        Weird. 😕
                        That makes no sense at all. Have you installed any new plugins lately? Maybe there is a conflict. Does the Ruby Console show any errors?
                        • PixeroP
                          Pixero
                          Here is what the console reports:
                          Error; #<NoMethodError; undefined method `to_l' for nil;NilClass>
                          C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;93;in `dialog'
                          C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;67;in `initialize'
                          C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;34;in `new'
                          C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;34;in `block in <top (required)>'
                          -e;1;in `call'
                          As a side note, would it be possible to have a setting for bevel size?
                          Like if I want half or even a quarter of the size of the bevel.
                          And some min and max distance of the random imperfections?
                          I think both are a litte too big for most cases.
                          • sdmitchS
                            sdmitch
                            > -e;1;in `call'
                            The error is occurring when the defaults are being read so use the "Reset" option first and hopefully that will clear up the problem.
                            I will consider your request as time permits.
                              Mra
                              I think there is a bug in the newest verision. On a rectangle it was complaining about non planar faces, even though this was off a box with sketchup box primitive.
                              Reverting back a version, I was then able to generate a wooden pattern on the same object.
                              • sdmitchS
                                sdmitch
                                I have experienced the same problem with wood on vertical faces. I can't imagine why but will try to sort it out.
                                Thanks for the heads up
                                • sdmitchS
                                  sdmitch
                                  Problem has been fixed. 💚 Quality control and testing director has been severely punished. 🤢
                                    Mra
                                    No problem. Thank YOU for such a cool plugin. Can't release images now, but having fun decorating inside of a cafe with wooden panels everywhere. I recommend everyone your plugins.
                                    • deaneauD
                                      deaneau
                                      Hello,
                                      i would design a special ground with your plugin
                                      here 3 pictures
                                      is this possible with your plugin?
                                      Translation for the picture
                                      A: Big Corner Part
                                      B: Sidewalk Main Part
                                      C Small Corner Part
                                      😧 Bishop's cap
                                      measure in cm
                                      25cm=9.8425in
                                      35cm=13.7795in
                                      49,5cm=19.4881in
                                      Gap 1cm=0.3937in
                                      This is a part of a typical sidewalk in Berlin
                                      here a german wiki page
                                      http://de.wikipedia.org/wiki/Pflaster_(Belag
                                      Thank you
                                      Dean
                                      • sdmitchS
                                        sdmitch
                                        It might be possible, in part at least, for a perfect size face but doubtful for a random size face. I'll see what I can do.
                                        • deaneauD
                                          deaneau
                                          that would be great,
                                          if you need a sketchup file i can send this via PM
                                          can i use this in a curve,too?
                                          thank you dean
                                          • sdmitchS
                                            sdmitch
                                            thank you dean
                                            Please do. I hate trying to guess.
                                            • 16
                                            • 17
                                            • 6 / 17
