    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 461.3k Views 109 Watching
    • sdmitchS
      sdmitch
      @djrique said:
      Upload .Rb file PT-BR Language: https://drive.google.com/file/d/0BwqiSt9yjVQDVHZCM1JCOS1wb0U/edit?usp=sharing
      i don´t know to create .rbz file... 😳
      THX.
      An .rbz file is just a .zip file with the extension changed to .rbz
      http://sdmitch.blogspot.com/
      • Mistro11M
        Mistro11
        Hope this render reflects my gratitude. 👍
        Structural Integrity is Not Just Physical...It's in the Design and Purpose
        • sdmitchS
          sdmitch
          It's beautiful. Thanks for making me look so good.
            sidewalk
            Excellent plugin! A tool like this has been on my wishlist for years.
            One suggestion: Is it possible to add an exterior clapboard/lap siding setting? The parameters could be very similar to the wood setting.
            • T
              toto ete
              great plugin! super work and thanks for sharing it!
              keep up the wonderful work!
              • PixeroP
                Pixero
                Suddenly I get the same error as mentioned above.
                When I change pattern the window closes.
                I've re installed the latest version and tried it on two PCs.
                Weird. 😕
                • sdmitchS
                  sdmitch
                  Weird. 😕
                  That makes no sense at all. Have you installed any new plugins lately? Maybe there is a conflict. Does the Ruby Console show any errors?
                  • PixeroP
                    Pixero
                    Here is what the console reports:
                    Error; #<NoMethodError; undefined method `to_l' for nil;NilClass>
                    C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;93;in `dialog'
                    C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;67;in `initialize'
                    C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;34;in `new'
                    C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;34;in `block in <top (required)>'
                    -e;1;in `call'
                    As a side note, would it be possible to have a setting for bevel size?
                    Like if I want half or even a quarter of the size of the bevel.
                    And some min and max distance of the random imperfections?
                    I think both are a litte too big for most cases.
                    • sdmitchS
                      sdmitch
                      > -e;1;in `call'
                      The error is occurring when the defaults are being read so use the "Reset" option first and hopefully that will clear up the problem.
                      I will consider your request as time permits.
                        Mra
                        I think there is a bug in the newest verision. On a rectangle it was complaining about non planar faces, even though this was off a box with sketchup box primitive.
                        Reverting back a version, I was then able to generate a wooden pattern on the same object.
                        • sdmitchS
                          sdmitch
                          I have experienced the same problem with wood on vertical faces. I can't imagine why but will try to sort it out.
                          Thanks for the heads up
                          • sdmitchS
                            sdmitch
                            Problem has been fixed. 💚 Quality control and testing director has been severely punished. 🤢
                              Mra
                              No problem. Thank YOU for such a cool plugin. Can't release images now, but having fun decorating inside of a cafe with wooden panels everywhere. I recommend everyone your plugins.
                              • deaneauD
                                deaneau
                                Hello,
                                i would design a special ground with your plugin
                                here 3 pictures
                                is this possible with your plugin?
                                Translation for the picture
                                A: Big Corner Part
                                B: Sidewalk Main Part
                                C Small Corner Part
                                😧 Bishop's cap
                                measure in cm
                                25cm=9.8425in
                                35cm=13.7795in
                                49,5cm=19.4881in
                                Gap 1cm=0.3937in
                                This is a part of a typical sidewalk in Berlin
                                here a german wiki page
                                http://de.wikipedia.org/wiki/Pflaster_(Belag
                                Thank you
                                Dean
                                • sdmitchS
                                  sdmitch
                                  It might be possible, in part at least, for a perfect size face but doubtful for a random size face. I'll see what I can do.
                                  • deaneauD
                                    deaneau
                                    that would be great,
                                    if you need a sketchup file i can send this via PM
                                    can i use this in a curve,too?
                                    thank you dean
                                    • sdmitchS
                                      sdmitch
                                      thank you dean
                                      Please do. I hate trying to guess.
                                      • deaneauD
                                        deaneau
                                        Suggestion for different Texture Packs.
                                        what do you think about different texture pack.
                                        in the texture folder i have different folders with diferent textures.
                                        this could be selected via dropdown.
                                        thank you Dean
                                        • deaneauD
                                          deaneau
                                          Hallo is this possible?
                                          green arrows mean only this direction(s) i want
                                          selected multiple face doing this in one step
                                          here what i have choose in preferences
                                          the wall in the backbround is a curved object.
                                          the result is this
                                          reason could be that a curved face is splitted in smaller face like this
                                          the wall part i want produce have an exact width of 1200mm (3' 11")
                                          or have anybody an other solution?
                                          download this file here
                                          Page Not Found
                                          Web word processing, presentations and spreadsheets
                                          (drive.google.com)
                                          the curved face havn´t the exaxt width 😕
                                          thank you
                                          • sdmitchS
                                            sdmitch
                                            Sorry but FloorGenerator only works on faces not surfaces. Even if hidden geometry is not displayed, when you pick a point on the surface you select just one of the faces that make up the surface.
                                            You could create a face with the overall dimensions of the surface. Then use Shape Bender to produce the curved surface after applying the tile pattern. A bit of work but all I can offer at this time.
                                            • 16
                                            • 17
                                            • 6 / 17
