    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 433.5k Views 109 Watching
    • sdmitchS
      sdmitch
      @djrique said:
      Thank you guy for that great plugin. I'm a brazilian and translated it for portuguese. Do you think that it's good?
      Good by me.
      http://sdmitch.blogspot.com/
        djrique
        Upload .Rb file PT-BR Language: https://drive.google.com/file/d/0BwqiSt9yjVQDVHZCM1JCOS1wb0U/edit?usp=sharing
        i don´t know to create .rbz file... 😳
        THX.
        • sdmitchS
          sdmitch
          THX.
          An .rbz file is just a .zip file with the extension changed to .rbz
          • Mistro11M
            Mistro11
            Hope this render reflects my gratitude. 👍
            i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
            Structural Integrity is Not Just Physical...It's in the Design and Purpose
            • sdmitchS
              sdmitch
              It's beautiful. Thanks for making me look so good.
                sidewalk
                Excellent plugin! A tool like this has been on my wishlist for years.
                One suggestion: Is it possible to add an exterior clapboard/lap siding setting? The parameters could be very similar to the wood setting.
                • T
                  toto ete
                  great plugin! super work and thanks for sharing it!
                  keep up the wonderful work!
                  • PixeroP
                    Pixero
                    Suddenly I get the same error as mentioned above.
                    When I change pattern the window closes.
                    I've re installed the latest version and tried it on two PCs.
                    Weird. 😕
                    • sdmitchS
                      sdmitch
                      Weird. 😕
                      That makes no sense at all. Have you installed any new plugins lately? Maybe there is a conflict. Does the Ruby Console show any errors?
                      • PixeroP
                        Pixero
                        Here is what the console reports:
                        Error; #<NoMethodError; undefined method `to_l' for nil;NilClass>
                        C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;93;in `dialog'
                        C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;67;in `initialize'
                        C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;34;in `new'
                        C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;34;in `block in <top (required)>'
                        -e;1;in `call'
                        As a side note, would it be possible to have a setting for bevel size?
                        Like if I want half or even a quarter of the size of the bevel.
                        And some min and max distance of the random imperfections?
                        I think both are a litte too big for most cases.
                        • sdmitchS
                          sdmitch
                          > -e;1;in `call'
                          The error is occurring when the defaults are being read so use the "Reset" option first and hopefully that will clear up the problem.
                          I will consider your request as time permits.
                            Mra
                            I think there is a bug in the newest verision. On a rectangle it was complaining about non planar faces, even though this was off a box with sketchup box primitive.
                            Reverting back a version, I was then able to generate a wooden pattern on the same object.
                            • sdmitchS
                              sdmitch
                              I have experienced the same problem with wood on vertical faces. I can't imagine why but will try to sort it out.
                              Thanks for the heads up
                              • sdmitchS
                                sdmitch
                                Problem has been fixed. 💚 Quality control and testing director has been severely punished. 🤢
                                  Mra
                                  No problem. Thank YOU for such a cool plugin. Can't release images now, but having fun decorating inside of a cafe with wooden panels everywhere. I recommend everyone your plugins.
                                  • deaneauD
                                    deaneau
                                    Hello,
                                    i would design a special ground with your plugin
                                    here 3 pictures
                                    is this possible with your plugin?
                                    Translation for the picture
                                    A: Big Corner Part
                                    B: Sidewalk Main Part
                                    C Small Corner Part
                                    😧 Bishop's cap
                                    measure in cm
                                    25cm=9.8425in
                                    35cm=13.7795in
                                    49,5cm=19.4881in
                                    Gap 1cm=0.3937in
                                    This is a part of a typical sidewalk in Berlin
                                    here a german wiki page
                                    http://de.wikipedia.org/wiki/Pflaster_(Belag
                                    Thank you
                                    Dean
                                    • sdmitchS
                                      sdmitch
                                      It might be possible, in part at least, for a perfect size face but doubtful for a random size face. I'll see what I can do.
                                      • deaneauD
                                        deaneau
                                        that would be great,
                                        if you need a sketchup file i can send this via PM
                                        can i use this in a curve,too?
                                        thank you dean
                                        • sdmitchS
                                          sdmitch
                                          thank you dean
                                          Please do. I hate trying to guess.
                                          • deaneauD
                                            deaneau
                                            Suggestion for different Texture Packs.
                                            what do you think about different texture pack.
                                            in the texture folder i have different folders with diferent textures.
                                            this could be selected via dropdown.
                                            thank you Dean
                                            • 16
                                            • 17
                                            • 6 / 17
