    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 439.8k Views 109 Watching
    • sdmitchS
      sdmitch
      @pixero said:
      Here is what the console reports:
      Error; #<NoMethodError; undefined method `to_l' for nil;NilClass>
      > C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;93;in `dialog'
      > C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;67;in `initialize'
      > C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;34;in `new'
      > C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb;34;in `block in <top (required)>'
      > -e;1;in `call'
      As a side note, would it be possible to have a setting for bevel size?
      Like if I want half or even a quarter of the size of the bevel.
      And some min and max distance of the random imperfections?
      I think both are a litte too big for most cases.
      The error is occurring when the defaults are being read so use the "Reset" option first and hopefully that will clear up the problem.
      I will consider your request as time permits.
      http://sdmitch.blogspot.com/
        Mra
        I think there is a bug in the newest verision. On a rectangle it was complaining about non planar faces, even though this was off a box with sketchup box primitive.
        Reverting back a version, I was then able to generate a wooden pattern on the same object.
        • sdmitchS
          sdmitch
          I have experienced the same problem with wood on vertical faces. I can't imagine why but will try to sort it out.
          Thanks for the heads up
          • sdmitchS
            sdmitch
            Problem has been fixed. πŸ’š Quality control and testing director has been severely punished. 🀒
              Mra
              No problem. Thank YOU for such a cool plugin. Can't release images now, but having fun decorating inside of a cafe with wooden panels everywhere. I recommend everyone your plugins.
              • deaneauD
                deaneau
                Hello,
                i would design a special ground with your plugin
                here 3 pictures
                is this possible with your plugin?
                Translation for the picture
                A: Big Corner Part
                B: Sidewalk Main Part
                C Small Corner Part
                😧 Bishop's cap
                measure in cm
                25cm=9.8425in
                35cm=13.7795in
                49,5cm=19.4881in
                Gap 1cm=0.3937in
                This is a part of a typical sidewalk in Berlin
                here a german wiki page
                http://de.wikipedia.org/wiki/Pflaster_(Belag
                Thank you
                Dean
                • sdmitchS
                  sdmitch
                  It might be possible, in part at least, for a perfect size face but doubtful for a random size face. I'll see what I can do.
                  • deaneauD
                    deaneau
                    that would be great,
                    if you need a sketchup file i can send this via PM
                    can i use this in a curve,too?
                    thank you dean
                    • sdmitchS
                      sdmitch
                      thank you dean
                      Please do. I hate trying to guess.
                      • deaneauD
                        deaneau
                        Suggestion for different Texture Packs.
                        what do you think about different texture pack.
                        in the texture folder i have different folders with diferent textures.
                        this could be selected via dropdown.
                        thank you Dean
                        • deaneauD
                          deaneau
                          Hallo is this possible?
                          green arrows mean only this direction(s) i want
                          selected multiple face doing this in one step
                          here what i have choose in preferences
                          the wall in the backbround is a curved object.
                          the result is this
                          reason could be that a curved face is splitted in smaller face like this
                          the wall part i want produce have an exact width of 1200mm (3' 11")
                          or have anybody an other solution?
                          download this file here
                          Page Not Found
                          Web word processing, presentations and spreadsheets
                          (drive.google.com)
                          the curved face havnΒ΄t the exaxt width πŸ˜•
                          thank you
                          • sdmitchS
                            sdmitch
                            Sorry but FloorGenerator only works on faces not surfaces. Even if hidden geometry is not displayed, when you pick a point on the surface you select just one of the faces that make up the surface.
                            You could create a face with the overall dimensions of the surface. Then use Shape Bender to produce the curved surface after applying the tile pattern. A bit of work but all I can offer at this time.
                            • deaneauD
                              deaneau
                              yes this i have try before i asking here, with Fredo Scale ( Radial Bending)
                              what you mean is Chris Fullmer Shape Bender.
                              i have never tried it before.
                              ok, this work.
                              now i have a problem. the segments have not the exact lenght.
                              your plugin AddPts2Curve was my help, to see where on the curve is the 1,2m point and the next etc.
                              I will try step by step all your plugins.
                              Helper like plugins will every time be welcome.
                              thank you
                              • T
                                tomot
                                @sdmitch Its the first time I see HTML code embedded in a Ruby script. Thanks for not using .rbs
                                It gives me some confidence and a template to redo some of my scripts incorporating HTML. πŸŽ‰
                                Finally I have an example & see how with HTML I can place pictures next to my drop-down boxes.
                                cheers!
                                my plugins
                                tomot
                                • sdmitchS
                                  sdmitch
                                  That's the way I learned what little I know.
                                  • deaneauD
                                    deaneau
                                    Hello Sam,
                                    is it possible to insert the feature that tiles is grouped?
                                    actually if i generate a floor i have only a main group.
                                    when tiles is grouped i can do random rotate with mover2.
                                    this will look a little bit more inperfect.
                                    in mover i can use random rotation in x,y or z axis and can insert the degree by value.
                                    thank you
                                    Dean
                                    • sdmitchS
                                      sdmitch
                                      @deaneau said:
                                      Hello Sam,
                                      Do you mean each individual brick is a group?
                                      That is what the "Random Imperfections" option is for. That feature was fixed and enhanced in the last update on 21-Sep
                                      thank you
                                      Dean
                                      [attachment=1:1zcdcsd3]<!-- ia1 -->_2014.10.07_23h12m17s_019_01006.jpg<!-- ia1 -->[/attachment:1zcdcsd3]
                                      [attachment=0:1zcdcsd3]<!-- ia0 -->_2014.10.07_23h29m06s_020_01007.jpg<!-- ia0 -->[/attachment:1zcdcsd3]
                                      • deaneauD
                                        deaneau
                                        i have seen your plugin "Random Rotation".
                                        in this plugin you could insert 3 checkmarks for x y z-axis.
                                        so i have the control for axis. actually looks that the rotation work in all axis.
                                        like this
                                        • deaneauD
                                          deaneau
                                          the random inperfection rotate in all axis.. some times i would have only a rotation in z-axis. a value in degree is helpful.
                                          when all tiles would be in own group..so i could work with mover2 and in the last step ungroup this tiles.
                                          ungrouping go faster than grouping if i have tiles more than 1000+ .
                                          thank you
                                          • sdmitchS
                                            sdmitch
                                            like this
                                            [attachment=0:2bd2nz7e]<!-- ia0 -->_2014.10.09_09h12m14s_003_01011.jpg<!-- ia0 -->[/attachment:2bd2nz7e]
                                            That plugin is for rotating whole components or groups not individual entities within the component or group.
                                            • 16
                                            • 17
                                            • 6 / 17
