    Use of the Plug In Store
    3 Posts 3 Posters 282 Views 3 Watching
    • K
      kellenraidfractal
      I downloaded the plugin store and was able to download and use the tools. But when I restarted SU 2014 later on, the tools did not load again. I don't have to ddownload the Plug In Store again and then use it to download the extensions again do I?
      • KrisidiousK
        Krisidious
        No, what version are you on? SketchUp 8? You may need to install it, close sketchup and then restart to set the plugin as visible. make sure you check mark it inside extensions.
        By: Kristoff Rand
        • TIGT
          In PC versions older than v2014 there are often issues with security permissions to the Plugins too...
          See this on how to set it up properly for v8 http://sketchucation.com/resources/tutorials/36-intermediate/811-setting-security-permissions-in-sketchup
          In v2014 the folder should automatically be made by SketchUp for each User, with FULL permissions...
          The Plugins > SketchUcation fool at the end of the list will open the Plugins folder for you so you can actually see what is installed - although you should never need to manually mess with its contents if you use the AutoInstall features available to you...
