    How can i render regular panorama in vray sketchup
    renderpluginsextensions
    4 Posts 3 Posters 1.9k Views 3 Watching
      sketchuh
      i am having trouble render a corridor scene in vray sketchup. because it's very narrow and i could move my camera back enough to create a front view of the shot. how can i tweak the camera setting to achieve a panorama picture just like you would take using an regular camera. it's 180 degrees not 360degress. and i dont want warped effect.
      thanks.
      i want a front view of the shot. when i turned it front view, it only render part of the coridor
        rspierenburg
        Well just like a regular camera your best bet would be to render several scenes and stitch them together in Photoshop or a similar program. The only other way I could think of would be to remove the opposite wall and render a large image and then just crop out the corridor portion.
        • V Offline
          valerostudio
          1. You can try ThomThoms Vray Toys and edit the ratio of your viewport in SU
            http://sketchucation.com/forums/viewtopic.php?t=15491
          2. You can play with the different camera types under your Phys Cam settings.
            sketchuh
            thanks for your replies!!!really appreciated.
