    Finding reversed faces after texturing?
    25 Posts 9 Posters 930 Views 9 Watching
      Kris, I don't have time for a game. You are not using Monochrome face style with the back face color set to magenta as you claimed earlier that you do. Either you are using Hidden Line face style with the background color set to something other than white or, if you are using Monochrome face style, you've set the back face color to the same color as the front face color.
      Hidden Line with Background Color Changed and Sky enabled.
      Monochrome with same Background color as above and Sky enabled.
      • KrisidiousK Offline
        Krisidious
        My two natural faces are light tan and dark grey because I prefer it on my eyes and I can see most backfaces easily. but when I want to really search for backfaces I use my backface style.
        and here's the other's settings
        By: Kristoff Rand
          AirWindSolar
          @dave r said:
          If you just work in Monochrome mode in the first place and fix face orientation as you go, you shouldn't need to be bouncing between face styles anyway.
          Problem is I have idiots over my shoulder all the time, so everything has to be color coded right away to reduce the "what size is that?" interruptions.
          • TIGT Online
            Just clicking between Textured and Monochrome view modes is hardly onerous πŸ˜’
            Get into the habit of doing it as you model...
            IT saves a lot of heartache at the end...
            • pbacotP Offline
              I often need alternate styles while working. I have scenes set up that change the style (and nothing else) so I can look at the presentation of export style, then switch to a style that is easier for working.
              • 2 / 2
