    V-Ray RT Render
    renderpluginsextensions
    3 Posts 2 Posters 1.6k Views 2 Watching
    • N Offline
      navonna99
      I have been having difficulty using the RT Render option. I select it and the V-Ray Progress window opens and so does the Frame Buffer and it says it is preparing the global light manager but it is stuck at 0% Sometimes it goes to 98% and then stops. Help!
      • massimoM Offline
        massimo Moderator
        Hi, do you know that there is a dedicated V-ray subforum under "Extensions & Applications Discussions"? You can post V-ray related questions there. I've moved all you posts in that subforum.
        • N Offline
          navonna99
          Thanks. I knew that but I forgot to put it in there.
