    Fishing net modeling
    131 Posts 12 Posters 24.1k Views 12 Watching
    • W Offline
      willipop
      thx you very much ! I will explore your method today. My sketchup still running its 36h of working progress now lol, it makes no sens as you pointed earlier on.
      • BoxB Offline
        William, if you turn edges on in that model you'll find the lines I used to make the mesh, off to the side.
        Using EEbyR, click one side, then the top then the bottom and finish on the other side, then say no to everything that pops up and you will have the mesh.
        I used selection toys to select and remove the faces. Then converted to tubes, with 3sides and unsoftened them.
        If you can't follow that I can make a video if you want.
        • W Offline
          willipop
          I'd love to ! if you have time 😄 What is selection toys ? thx again !
          • W Offline
            willipop
            I did have succes o use EEbyR 😄 but how to chose the number of edges ( having more or less faces created ?)
              The problem is I can't use tig's extrusion tools
              lequel exactement ? 😄
              Le truc à savoir pour tous les outils Extrude de TIG
              Clic 1 = Profil
              Clic 2 = Rail 1
              Clic 3 = Rail 2
              Clic 4 = Profil de fin
              Quand il n'y a pas 2 rails ou 2 profils on clique quand même sur le même rail ou le même profil pour avoir les 4 clics dans l'ordre! 🤓
              http://forums.polyloop.net/picture.php?albumid=23&pictureid=586
              http://www.polyloop.net/attachment.php?attachmentid=29139&stc=1&d=1260011015
              http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=24627;image
              Avantage des Extrudes de TIG!
              http://forums.polyloop.net/picture.php?albumid=23&pictureid=633
              • BoxB Offline
                There are quite a few ways, but do you have Bezier tools, it give you the option to right click on a line and select polyline segmentor. Here you can type in the number of segments you want.
                Selection toys is a plugin by thomthom.
                • BoxB Offline
                  Short vid for net.
                  [screenr:4ch62smu]4e1N[/screenr:4ch62smu]
                    Les courbes opposées doivent le même nombre de segments sinon c'est des calculs en plus! 🤓
                    • W Offline
                      willipop
                      very cool thx a lot guys !
                      • W Offline
                        willipop
                        It crashed after 40h of working 😞😞
                        • W Offline
                          willipop
                          I kind of like the shape of it. I applied a transparent texture and cast shadows from the edges. Is it possible to this with kerkythea or artlantis for the rendering.
                          My file is about 42 megs I can share a wetransfer link if someone wants to play with it 😄
                          • BoxB Offline
                            How big is the model without the net, if it's less than 4mg you could upload it here.
                            I wouldn't mind having a look at the structure and seeing if there is a simple way to make the net.
                            • W Offline
                              willipop
                              It's 26meg but I guess if you delete the bridge it's less than a meg.
                              Here's the link : http://we.tl/3Zg9yeDhRw
                              If you could make a video that could be perfect 😄 I have 2 scenario to do. One with the net that is lower and one upper. If you notice, there is a line at the extreme end of the bridge, it's about 2.5meter high. The net must not drop above this line. It's why I liked playing with artisan I was able to set a limit 😄
                              • BoxB Offline
                                Bit of a tip for you.
                                Purge your file and it is only 1.8mg
                                bridge1.skp
                                • W Offline
                                  willipop
                                  oh wow ! 😄 I feel ashamed ehehe 😛
                                  • olisheaO Offline
                                    olishea
                                    Is the model any quicker now it's been purged?
                                    If you absolutely must use the model you already have, you could always overlay the sketchup lines and shadows onto your render. The shadows can be blurred in photoshop for realism. You can do a hidden line export and then overlay these onto your render in photoshop. Change the blending mode to "multiply" and all the white disappears, leaving only the lines. This is kinda cheating though! I'd rather have a model that renders from all scenes, without having to overlay lines.
                                    Here is a VERY old tutorial, from David Huang (Zem) where I learnt the overlay or "lineover" technique. You can have a line export and a shadow export in separate images giving more flexibility in photoshop when you are overlaying everything. So basically; render at the bottom, then shadows, then lines.
                                    It would still be better in the long run if you find a solution that does not involve line exports etc....
                                    http://supodiumforum.websitetoolbox.com/file?id=724830
                                    Love this thread; food for thought and some great contribution! 👍
                                    oli
                                    • W Offline
                                      willipop
                                      @ Oli : I'm considering this option but the shadow produced from edges by sketchup is not that precise I think... 😞 Here is a nice tutorial of one architect I like a lot that explain very well what you just bring 😄 : Alex hogrefe : http://alexhogrefe.squarespace.com/ambient-occlusion-tutorial/
                                      • BoxB Offline
                                        Is this anything like what you want?
                                        • W Offline
                                          willipop
                                          Wow it's very nice 😄 It's close to what I have in mind. I'd love the net more dense. Could you show me how you did that and I will try myself !? How did you did the rendering ? very cool !
                                          • W Offline
                                            willipop
                                            I think I will have to go with something similar you did ( I mean more space between each squares of the mesh )
                                            • 6
                                            • 7
                                            • 5 / 7
