    Fishing net modeling
    131 Posts 12 Posters 20.5k Views 12 Watching
    • BoxB Offline
      There are quite a few ways, but do you have Bezier tools, it give you the option to right click on a line and select polyline segmentor. Here you can type in the number of segments you want.
      Selection toys is a plugin by thomthom.
      • BoxB Offline
        Short vid for net.
        [screenr:4ch62smu]4e1N[/screenr:4ch62smu]
          Les courbes opposรฉes doivent le mรชme nombre de segments sinon c'est des calculs en plus! ๐Ÿค“
          • W Offline
            willipop
            very cool thx a lot guys !
            • W Offline
              willipop
              It crashed after 40h of working ๐Ÿ˜ž๐Ÿ˜ž
              • W Offline
                willipop
                I kind of like the shape of it. I applied a transparent texture and cast shadows from the edges. Is it possible to this with kerkythea or artlantis for the rendering.
                My file is about 42 megs I can share a wetransfer link if someone wants to play with it ๐Ÿ˜„
                • BoxB Offline
                  How big is the model without the net, if it's less than 4mg you could upload it here.
                  I wouldn't mind having a look at the structure and seeing if there is a simple way to make the net.
                  • W Offline
                    willipop
                    It's 26meg but I guess if you delete the bridge it's less than a meg.
                    Here's the link : http://we.tl/3Zg9yeDhRw
                    If you could make a video that could be perfect ๐Ÿ˜„ I have 2 scenario to do. One with the net that is lower and one upper. If you notice, there is a line at the extreme end of the bridge, it's about 2.5meter high. The net must not drop above this line. It's why I liked playing with artisan I was able to set a limit ๐Ÿ˜„
                    • BoxB Offline
                      Bit of a tip for you.
                      Purge your file and it is only 1.8mg
                      bridge1.skp
                      • W Offline
                        willipop
                        oh wow ! ๐Ÿ˜„ I feel ashamed ehehe ๐Ÿ˜›
                        • olisheaO Offline
                          olishea
                          Is the model any quicker now it's been purged?
                          If you absolutely must use the model you already have, you could always overlay the sketchup lines and shadows onto your render. The shadows can be blurred in photoshop for realism. You can do a hidden line export and then overlay these onto your render in photoshop. Change the blending mode to "multiply" and all the white disappears, leaving only the lines. This is kinda cheating though! I'd rather have a model that renders from all scenes, without having to overlay lines.
                          Here is a VERY old tutorial, from David Huang (Zem) where I learnt the overlay or "lineover" technique. You can have a line export and a shadow export in separate images giving more flexibility in photoshop when you are overlaying everything. So basically; render at the bottom, then shadows, then lines.
                          It would still be better in the long run if you find a solution that does not involve line exports etc....
                          Human Verification
                          (supodiumforum.websitetoolbox.com)
                          Love this thread; food for thought and some great contribution! ๐Ÿ‘
                          oli
                          • W Offline
                            willipop
                            @ Oli : I'm considering this option but the shadow produced from edges by sketchup is not that precise I think... ๐Ÿ˜ž Here is a nice tutorial of one architect I like a lot that explain very well what you just bring ๐Ÿ˜„ : Alex hogrefe : http://alexhogrefe.squarespace.com/ambient-occlusion-tutorial/
                            • BoxB Offline
                              Is this anything like what you want?
                              • W Offline
                                willipop
                                Wow it's very nice ๐Ÿ˜„ It's close to what I have in mind. I'd love the net more dense. Could you show me how you did that and I will try myself !? How did you did the rendering ? very cool !
                                • W Offline
                                  willipop
                                  I think I will have to go with something similar you did ( I mean more space between each squares of the mesh )
                                  • W Offline
                                    willipop
                                    woaa this plugin is amazing ! you rock ๐Ÿ˜„
                                    • BoxB Offline
                                      You can go denser, that whole file is only 6mg and doesn't lag at all with shadows.
                                      I used another plugin called Wire tool to link the construction points with a nice droop. Then just did as I did in the video. for each section.
                                      I only used 12 segments for the curves, so that makes it quite wide, you can use more to get a finer mesh. http://sketchucation.com/pluginstore?pln=ae_WireTool
                                      You may want to use the main wires as thicker support cables, then make the mesh between.
                                      But it's up to you how you want it to look.
                                      The trick though is to make it using copies as much as possible. Make one end and flip the components to work on the other end etc
                                      The render is just a basic preset render from twilight. And as you can see in this one when I flipped it it didn't fit because you structure isn't symmetrical, hence the gap in the middle.
                                      A finer mesh with some thick cables
                                      • W Offline
                                        willipop
                                        This plugin makes it looks really nice !
                                        Is there another plugin that I could use to fix some summit and use some other summit that I could move.(just like artisan works with the crease tool.) vertex tool ?
                                        • olisheaO Offline
                                          olishea
                                          gets better and better! I forgot about the wire tool, it's a classic!
                                          oli
                                            Perfect for some hammock! โ˜€
                                            Au fait j'ai fait la version francophone d'Artisan! ๐Ÿ˜‰
                                            http://www.endalldisease.com/wp-content/uploads/2013/09/hammock.jpg
                                            Normally Su make that in native ? ๐Ÿ˜„
                                            Sรฉlection verrouillรฉe ou non ?
                                            • 5 / 7
