    Fishing net modeling
    131 Posts 12 Posters 26.2k Views 12 Watching
    • W
      willipop
      It looks amazing ! It's white just like I imagine it ๐Ÿ˜„ Is this a texture or it's lines converted to tubes ?
      The problem is I can't use tig's extrusion tools, each time I'm having hard time, there's something I don't understand with this plugin... ๐Ÿ˜• can you upload the file Box ? Very nice job !
      • W
        willipop
        thx you very much ! I will explore your method today. My sketchup still running its 36h of working progress now lol, it makes no sens as you pointed earlier on.
        • BoxB
          William, if you turn edges on in that model you'll find the lines I used to make the mesh, off to the side.
          Using EEbyR, click one side, then the top then the bottom and finish on the other side, then say no to everything that pops up and you will have the mesh.
          I used selection toys to select and remove the faces. Then converted to tubes, with 3sides and unsoftened them.
          If you can't follow that I can make a video if you want.
          • W
            willipop
            I'd love to ! if you have time ๐Ÿ˜„ What is selection toys ? thx again !
            • W
              willipop
              I did have succes o use EEbyR ๐Ÿ˜„ but how to chose the number of edges ( having more or less faces created ?)
                lequel exactement ? ๐Ÿ˜„
                Le truc ร  savoir pour tous les outils Extrude de TIG
                Clic 1 = Profil
                Clic 2 = Rail 1
                Clic 3 = Rail 2
                Clic 4 = Profil de fin
                Quand il n'y a pas 2 rails ou 2 profils on clique quand mรชme sur le mรชme rail ou le mรชme profil pour avoir les 4 clics dans l'ordre! ๐Ÿค“
                http://forums.polyloop.net/picture.php?albumid=23&pictureid=586
                http://www.polyloop.net/attachment.php?attachmentid=29139&stc=1&d=1260011015
                http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=24627;image
                Avantage des Extrudes de TIG!
                http://forums.polyloop.net/picture.php?albumid=23&pictureid=633
                • BoxB
                  There are quite a few ways, but do you have Bezier tools, it give you the option to right click on a line and select polyline segmentor. Here you can type in the number of segments you want.
                  Selection toys is a plugin by thomthom.
                  • BoxB
                    Short vid for net.
                    [screenr:4ch62smu]4e1N[/screenr:4ch62smu]
                      Les courbes opposรฉes doivent le mรชme nombre de segments sinon c'est des calculs en plus! ๐Ÿค“
                      • W
                        willipop
                        very cool thx a lot guys !
                        • W
                          willipop
                          It crashed after 40h of working ๐Ÿ˜ž๐Ÿ˜ž
                          • W
                            willipop
                            I kind of like the shape of it. I applied a transparent texture and cast shadows from the edges. Is it possible to this with kerkythea or artlantis for the rendering.
                            My file is about 42 megs I can share a wetransfer link if someone wants to play with it ๐Ÿ˜„
                            • BoxB
                              How big is the model without the net, if it's less than 4mg you could upload it here.
                              I wouldn't mind having a look at the structure and seeing if there is a simple way to make the net.
                              • W
                                willipop
                                It's 26meg but I guess if you delete the bridge it's less than a meg.
                                Here's the link : http://we.tl/3Zg9yeDhRw
                                If you could make a video that could be perfect ๐Ÿ˜„ I have 2 scenario to do. One with the net that is lower and one upper. If you notice, there is a line at the extreme end of the bridge, it's about 2.5meter high. The net must not drop above this line. It's why I liked playing with artisan I was able to set a limit ๐Ÿ˜„
                                • BoxB
                                  Bit of a tip for you.
                                  Purge your file and it is only 1.8mg
                                  bridge1.skp
                                  • W
                                    willipop
                                    oh wow ! ๐Ÿ˜„ I feel ashamed ehehe ๐Ÿ˜›
                                    • olisheaO
                                      olishea
                                      Is the model any quicker now it's been purged?
                                      If you absolutely must use the model you already have, you could always overlay the sketchup lines and shadows onto your render. The shadows can be blurred in photoshop for realism. You can do a hidden line export and then overlay these onto your render in photoshop. Change the blending mode to "multiply" and all the white disappears, leaving only the lines. This is kinda cheating though! I'd rather have a model that renders from all scenes, without having to overlay lines.
                                      Here is a VERY old tutorial, from David Huang (Zem) where I learnt the overlay or "lineover" technique. You can have a line export and a shadow export in separate images giving more flexibility in photoshop when you are overlaying everything. So basically; render at the bottom, then shadows, then lines.
                                      It would still be better in the long run if you find a solution that does not involve line exports etc....
                                      Unknown Forum
                                      (supodiumforum.websitetoolbox.com)
                                      Love this thread; food for thought and some great contribution! ๐Ÿ‘
                                      oli
                                      • W
                                        willipop
                                        @ Oli : I'm considering this option but the shadow produced from edges by sketchup is not that precise I think... ๐Ÿ˜ž Here is a nice tutorial of one architect I like a lot that explain very well what you just bring ๐Ÿ˜„ : Alex hogrefe : http://alexhogrefe.squarespace.com/ambient-occlusion-tutorial/
                                        • BoxB
                                          Is this anything like what you want?
                                          • W
                                            willipop
                                            Wow it's very nice ๐Ÿ˜„ It's close to what I have in mind. I'd love the net more dense. Could you show me how you did that and I will try myself !? How did you did the rendering ? very cool !
                                            • 5 / 7
