    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Fishing net modeling
    131 Posts 12 Posters 13.5k Views 12 Watching
    • W Offline
      willipop
      Hi everybody !
      I'm trying to make a model of a giant fishing net and I'm wondering if there's anyway or plugin available to do it.
      So far I already tried pipe along path wich makes my sketchup crash.
      I did achieve small scale success with the 1001 bit tools architecture plugin using Rectangular grille and circular grille tool, but it seems to add too much vertex and sketchup crash when I'm tying to apply it on a large wireframe surface.
      The actual method I'm using is :
      1 : I make the surface wich is about 50m x 8m with ondulation
      2 : I use artisan plugin to add vertex with the subdivide selection tool
      3 : I turn on hidden geometry and choose the style wireframe to only see the wireframes
      4 : I select the wireframe of the surface and apply the Rectangular grille tool of the 1001 bit tools pluggin
      Is there a better way to do this ? Thanks for your help !
      Willipop
      • cottyC Offline
        cotty
        Do you habe an example picture of the desired net?
        my SketchUp gallery
        • W Offline
          willipop
          Not as precise as this but here is the big picture :
          • BoxB Offline
            Have a look at Tig's extrusion tools, particularly Extrude Edges by Rails to Lattice.
            • W Offline
              willipop
              I have this plugin, I'll try it right away ! Could tell me what is a lattice ?
              Thanks for the help guys !
              • W Offline
                willipop
                I'm having trouble with selecting the profile curve ... should I still work in wireframe style while using this tool ?
                • W Offline
                  willipop
                  Is there a way to transform wireframes to edges ?
                    How about posting your SKP file so we can actually see what you've got?
                    • BoxB Offline
                      Just as a start, this is a lattice made quickly with tigs tool.
                      • W Offline
                        willipop
                        Very nice Box !
                        Can you set the thickness of the lattice ?
                        I added a quick test (sketchup v8) but I'm using 2014.
                        fishnettest.skp
                        • BoxB Offline
                          Yes you can change the thickness.
                          But you need to think about the complexity of the geometry you want to create. A huge complex net made in one piece will bring any computer to it's knees.
                          If you want to do it make it in repeatable sections as components.
                          Or consider using a nice net texture. The image below is one of the default fencing textures.
                          • W Offline
                            willipop
                            I see ! The problem with the textrure is it won't cast the shadows !?
                            • cottyC Offline
                              cotty
                              Example how to use Artisan to create the basic shape for texturing...
                              my SketchUp gallery
                              • W Offline
                                willipop
                                Super cool cotty ! how did you pass from the middle shape to 3rd shape at the very right ? Is this actual edges ?
                                • W Offline
                                  willipop
                                  @ Cotty, can you upload your file ?
                                  • cottyC Offline
                                    cotty
                                    I followed Boxs suggestion with the simple fence texture...
                                    The model is attached.
                                    netartisan_cotty.skp
                                    my SketchUp gallery
                                    • W Offline
                                      willipop
                                      I'm wondering if there is a way to turn hidden geometry lines into edges !?
                                      • olisheaO Offline
                                        olishea
                                        Yes, unsoften them. Select all and slide the soften edges slider. Uncheck both the boxes too.
                                        oli
                                        • W Offline
                                          willipop
                                          Thx Oli ! I noticed we can change the weight of the edges in the style option but it is just for the display and it do not affect the weight of the shadows casted. Is there any other way too make the edges solid ?
                                          • W Offline
                                            willipop
                                            Here is a try I did today.
                                            1- Sarted with a rectangle
                                            2- Applyed several time the subdivide selection tool from artisan
                                            3- Applyed the subdivide and smooth tool from artisan
                                            4- Turned on hidden line and selected style wireframe
                                            5- Selected the lines and get rid of the smoothing edges to get edges
                                            6- copied those edges
                                            7- Finally I used tube to cylinder plugin and It took 10 min approx of working progress
                                            I'll have no choice to go with this kind of work flow if I don't find anything better than this. End of semester is coming fast ๐Ÿ˜›
                                            • 6
                                            • 7
                                            • 2 / 7
