    [REQ] un-select everything
    34 Posts 15 Posters 1.6k Views 15 Watching
    • soloS Offline
      solo
      I wonder if it's just me or do any other users get frustrated when editing groups or components nested deep within each other and want to exit out, normally I'd click on empty spaces but what if I'm doing an interior and there are no empty spaces? So, I'm looking for a button to press and it exits all edits and unselects everything keeping me in the same view.
      Normally I set up a scene outside of model which I click on then select open space to exit the component, but that takes me out from current view I'd rather have a quicker way to unselect and exit edit mode.
      Make sense?
      http://www.solos-art.com
        Does the ESC key not do it? On phone at the mo so can't check it
        • fredo6F Offline
          fredo6
          That's a one-liner
          while Sketchup.active_model.close_active ; end
          Apparently, this also clears the selection if any
          ESC does it too, but step by step
          Fredo
          • soloS Offline
            solo
            8 years using SU almost everyday, I have never tried that, I thought I'd had all the needed hot keys programmed on my 3D navigator, so ESC was never considered. I feel like an idiot, need to demote myself to beginner status. 😳
            • massimoM Offline
              massimo Moderator
              • jeff hammondJ Offline
                jeff hammond
                fwiw, on mac, esc doesn't clear a selection(s)..
                it's cmmd-A for select all & shift-cmmd-A for deselect all
                dotdotdot
                • gillesG Offline
                  gilles
                  It does for me or maybe I've a fake Mac πŸ’š
                    jeff hammond
                    really? that's strange.
                    do you use an english keyboard? or- i wonder what else may be the reason why ESC deselects for you and not me?
                    dotdotdot
                    • gillesG Offline
                      gilles
                      AZERTY, do you think this could make a difference?
                      • KrisidiousK Offline
                        Krisidious
                        Esc does work and I use it often... But something to exit out of all groups and unselect everything back to the top of the model hierarchy would be nice.
                        By: Kristoff Rand
                        • gillesG Offline
                          gilles
                          It does not work with some tools when they are active.
                          • massimoM Offline
                            massimo Moderator
                            This works like a charm.
                              Krisidious
                              Crap... another context menu item... I'm already having spanning issues on my context menu. Oh well, one more to add to the party. Thanks Massimo.
                              By: Kristoff Rand
                                jeff hammond
                                not sure.. i guess a few more mac users would have to try it to see..
                                also, i wonder if everyone in the thread is talking about the same thing and i might of replied too quickly prior to fully understanding the question.
                                are we talking about exiting groups or un-selecting selected items? πŸ˜• i'll read back through the thread a little later.
                                dotdotdot
                                  Exiting editing mode from nested groups
                                  • gillesG Offline
                                    gilles
                                    Both.
                                    • pbacotP Offline
                                      I just use the key command for exit group... But you mean altogether out of all nested groups?
                                      I would also like a command to be able to click on an object and have it open that objects group immediately, no mater how nested.
                                        driven
                                        @jeff,
                                        esc works on my iMac. but I have never used it...
                                        I don't think it did on my mac book, so haven't tried it since...
                                        john
                                          DOD3R
                                          Hi all,
                                          I use ESC to exit components/groups i have no problem with that. I dont even need a function exit all, because its not that difficult to hit esc four times to exit from the nested group. And even i thing it helps me to be aware on witch layer in the nest am I.
                                          But still sometimes I loose track of things and i would like some visual clue. I know there is outliner and it serves this purpose well. But it gets messy sometimes and for good orientation takes a lot of my screen space. I would like something illustrator has. see attachment.
                                          what do you think?
                                          T.
                                            Sure if all components are named "Component"! πŸ’š
                                            • 2 / 2
