    Best Rendering Software
    extensions
    50 Posts 19 Posters 9.9k Views 19 Watching
    • N
      navonna99
      I am using SketchUp 2014 and have a trial version of V-Ray. I am also interested in Lumion. What are the best rendering programs for Sketchup? Also, I am new to SketchUcation and I did a post yesterday and replied to the Post but my reply does not show up -- what happened? I hit the "Submit" button but it does not submit.
      • PixeroP
        Pixero
        It depends... on what you want to do, your skill, and how fast you need a render done.
        I use Vray and Thea and more and more I use Thea for it's quality and quick set up time.
        It might be a bit slower for raytrace heavy scenes but over all (including set up time and test renders) I find it faster.
        With the latest version 1.3 it has a combined CPU and GPU engine that is very fast for many typical scenes.
        • massimoM
          massimo Moderator
          @navonna99 said:
          ...Also, I am new to SketchUcation and I did a post yesterday and replied to the Post but my reply does not show up -- what happened? I hit the "Submit" button but it does not submit.
          New members must wait for the approval of a moderator for the first couple of posts.
          • J
            JGA
            There are so many good rendering engines available for SKUP, but iin the end it's down to the user. Kerkythea is a good starting point being free with a good.forum support. Twilight builds on this, then you can migrate to Thea if you want to develop further. It's also compatible with other.modelling packages.
            Regards,
            JGA
            • DanielD
              Daniel
              A lot of software companies offer a free trial personal learning edition. You might consider taking some for a test drive before buying the car. Which software is best is subjective to the user...and the size of your wallet. 😉
              My avatar is an anachronism.
              • J
                jman0war
                I have been out of the loop for awhile.
                I used to use SU6.
                I had purchased SUPodium for rendering inside SU but it was way too slow.
                I then moved on to Vue Pro Studio. Results were amazing, but again very slow.
                So i'm looking for a suggestion for rendering inside SU (after i buy the latest version).
                It's primarily for exterior architectural scenes.
                I'd like to be able to include 3d trees, lush grass and my own textures.
                Bump maps or even Normal mapping support would be good too.
                Any suggestion?
                • DanielD
                  Daniel
                  You might try Vue by eon software. Besides the full version (Vue Infinite), they offer two architectural bundles at lower prices.
                  • jiminy-billy-bobJ
                    jiminy-billy-bob
                    Vray!
                    • J
                      JGA
                      You seem to have a good basis with Podium & Vue. Perhaps you need to upgrade your PC?
                      If you have a 64 OS, it may be an idea to have a renderer separate from SKUP, as it remains a 32 bit application - which also limits the built in renderer package.
                      Regards,
                      JGA
                      • J
                        jman0war
                        Ah ok, i didn't realize that.
                        Thing is, it would take a very long time to setup my scenes in Vue.
                        I want to omit the whole - exporting my model and all the nuances involved like triangulating faces, re-naming texture files etc.
                        If I could model in SU, and render there too, that would be best.
                        I won't be going with SUPodium, while I had the very original first release, it's just not perfect way too slow.
                        I haven't used VRAY, what about that Kerkythea?
                        Can i render my scenes without exporting etc?
                        Then add detail into my modeland render again?
                        • jiminy-billy-bobJ
                          jiminy-billy-bob
                          With Vray, everything is done inside SU. You can even render with 64bit without leaving SU.
                          • jiminy-billy-bobJ
                            jiminy-billy-bob
                            Thea also seems very powerfull, though I haven't deeply tried it.
                            Octane seems promising, but it has not been released yet.
                            • StinkieS
                              Stinkie
                              Try the latest version. I am confident you'll be surprised.
                              • J
                                jman0war
                                Sounds and looks great, but $835.00 is way, way too much to spend.
                                  Mitsuba it's free ! 😄
                                  • mitcorbM
                                    mitcorb
                                    Hello:
                                    Here is a listing you may not have seen:
                                    http://sketchucation.com/forums/viewtopic.php?f=81%26amp;t=3220#p15472
                                    Or, here:
                                    http://sketchuprendering.com/
                                    • J
                                      jman0war
                                      Mitsuba looks interesting.
                                      But it looks a little crude yet.
                                      Fake Grass via Motion Blur is a cool and creative solution, but I remain a little unconvinced.
                                      Do you know of any large renderings of outdoor architectural scenes where I can see the results?
                                      • KrisidiousK
                                        Krisidious
                                        I don't do any paid renders and I'm not very good at it... But I can tell you which one I've been wanting. Thea Presto.
                                        http://www.thearender.com/cms/index.php/plugins/thea-for-sketchup.html
                                        By: Kristoff Rand
                                        • J
                                          jman0war
                                          Sure, but you have to export the model.
                                          That's exactly the step i'm looking to omit.
                                          • KrisidiousK
                                            Krisidious
                                            Are any of them truly, actually inside sketchup? What's the problem with exporting? are you on freemake?
                                            By: Kristoff Rand
                                            • 1 / 3
