    Best Rendering Software
    extensions
    50 Posts 19 Posters 9.1k Views 19 Watching
    • massimoM Offline
      massimo Moderator
      @navonna99 said:
      ...Also, I am new to SketchUcation and I did a post yesterday and replied to the Post but my reply does not show up -- what happened? I hit the "Submit" button but it does not submit.
      New members must wait for the approval of a moderator for the first couple of posts.
        JGA
        There are so many good rendering engines available for SKUP, but iin the end it's down to the user. Kerkythea is a good starting point being free with a good.forum support. Twilight builds on this, then you can migrate to Thea if you want to develop further. It's also compatible with other.modelling packages.
        Regards,
        JGA
        • DanielD Offline
          Daniel
          A lot of software companies offer a free trial personal learning edition. You might consider taking some for a test drive before buying the car. Which software is best is subjective to the user...and the size of your wallet. 😉
          My avatar is an anachronism.
            jman0war
            I have been out of the loop for awhile.
            I used to use SU6.
            I had purchased SUPodium for rendering inside SU but it was way too slow.
            I then moved on to Vue Pro Studio. Results were amazing, but again very slow.
            So i'm looking for a suggestion for rendering inside SU (after i buy the latest version).
            It's primarily for exterior architectural scenes.
            I'd like to be able to include 3d trees, lush grass and my own textures.
            Bump maps or even Normal mapping support would be good too.
            Any suggestion?
            • DanielD Offline
              Daniel
              You might try Vue by eon software. Besides the full version (Vue Infinite), they offer two architectural bundles at lower prices.
              • jiminy-billy-bobJ Offline
                jiminy-billy-bob
                Vray!
                  JGA
                  You seem to have a good basis with Podium & Vue. Perhaps you need to upgrade your PC?
                  If you have a 64 OS, it may be an idea to have a renderer separate from SKUP, as it remains a 32 bit application - which also limits the built in renderer package.
                  Regards,
                  JGA
                    jman0war
                    Ah ok, i didn't realize that.
                    Thing is, it would take a very long time to setup my scenes in Vue.
                    I want to omit the whole - exporting my model and all the nuances involved like triangulating faces, re-naming texture files etc.
                    If I could model in SU, and render there too, that would be best.
                    I won't be going with SUPodium, while I had the very original first release, it's just not perfect way too slow.
                    I haven't used VRAY, what about that Kerkythea?
                    Can i render my scenes without exporting etc?
                    Then add detail into my modeland render again?
                      jiminy-billy-bob
                      With Vray, everything is done inside SU. You can even render with 64bit without leaving SU.
                        jiminy-billy-bob
                        Thea also seems very powerfull, though I haven't deeply tried it.
                        Octane seems promising, but it has not been released yet.
                        • StinkieS Offline
                          Stinkie
                          Try the latest version. I am confident you'll be surprised.
                            jman0war
                            Sounds and looks great, but $835.00 is way, way too much to spend.
                              Mitsuba it's free ! 😄
                              • mitcorbM Offline
                                mitcorb
                                Hello:
                                Here is a listing you may not have seen:
                                http://sketchucation.com/forums/viewtopic.php?f=81%26amp;t=3220#p15472
                                Or, here:
                                http://sketchuprendering.com/
                                  jman0war
                                  Mitsuba looks interesting.
                                  But it looks a little crude yet.
                                  Fake Grass via Motion Blur is a cool and creative solution, but I remain a little unconvinced.
                                  Do you know of any large renderings of outdoor architectural scenes where I can see the results?
                                  • KrisidiousK Offline
                                    Krisidious
                                    I don't do any paid renders and I'm not very good at it... But I can tell you which one I've been wanting. Thea Presto.
                                    http://www.thearender.com/cms/index.php/plugins/thea-for-sketchup.html
                                    By: Kristoff Rand
                                      jman0war
                                      Sure, but you have to export the model.
                                      That's exactly the step i'm looking to omit.
                                        Krisidious
                                        Are any of them truly, actually inside sketchup? What's the problem with exporting? are you on freemake?
                                        By: Kristoff Rand
                                        • soloS Offline
                                          No you do not, I use Thea 100% in SU, never export to studio.
                                          • andybotA Offline
                                            andybot
                                            Kris - is Presto inside SU - as opposed to Thea which has that studio thing? Or does Presto have to export to a studio as well? I am assuming jman0war is referring to a manual export process - where it's possible to make changes in an external studio that are not necessarily transferred back to SU.
                                            Edit: I see Pete has answered...
                                            • 1 / 3
